painting engine bay.....steering box ?'s
Old Sep 12, 2003 | 12:20 AM
85IrocNOH's Avatar
Car: 85 Iroc-Z
Axle/Gears: 10-bolt 3.42
i'm painting the engine bay of the iroc. i have everything stripped out except the steering box and linkage. i was just wondering what i'd be getting myself into if i took that stuff out. is there anything special i should do? also, on the steering box there are 2 (i think) big bolts that hold it to the frame rail;how much do those have to be torqued back down if i do take the box off?
http://irocznoh.50megs.com/misc/index.htm
http://irocznoh.50megs.com/enginebay/index.htm
Old Sep 12, 2003 | 11:59 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
There are actually three bolts, one is partially hidden behind the brace. 11/16 socket and my Haynes says 80 ft-lbs.
Seperate the center link from the pitmam arm, remove the bolt through the steering shaft under the brake booster (what brake booster?) and unhook the lines going to the cooler, or leave them attached and remove the entire thing.
Pete
Old Sep 12, 2003 | 03:45 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
Pete pretty much hit it dead on. When I redid my car I removed the steering box for paint. It was no problem at all to remove or install.
Good luck.
Old Sep 12, 2003 | 03:50 PM
85IrocNOH's Avatar
Car: 85 Iroc-Z
cool. thanks. i'll see about getting that out tonight.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
