How's this for a thirdgen tow bar!!
Old Sep 14, 2003 | 05:20 PM
Andy Fanshawe's Avatar
Car: 91 camaro rs
Seen at a local car show.
Good design or what?
Andy.
Old Sep 14, 2003 | 05:24 PM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
I'm not much into engineering, but shouldn't that tow bar be connected to the rear sub frames? I don't think the pan of the rear trunk can support any kind of towing load.
Old Sep 14, 2003 | 05:28 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
I wouldn't tow my daughters tricycle with that getup! That person who owns that car has less brains then that bar has support!!
Old Sep 14, 2003 | 06:12 PM
screaminformula's Avatar
Car: 1987 F150...PAAARTY FOUL!
Engine: 300 I6 stump pullin sumbiscuit
Transmission: 4 speed grind box
Axle/Gears: 3.55 unlimited slip differential
i wouldn't trust that just to support the weight of the HITCH ITSELF!!
Josh
Old Sep 14, 2003 | 06:20 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
Not a good design at all
Old Sep 14, 2003 | 07:05 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
I wonder if he knows how thin sheetmetal is. IIRC floor pans are about .100 thousanths thick.
Old Sep 14, 2003 | 07:36 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
thats not good at all, i had a tow hitch on my car when i got it and it was bolted to the subframes not to a thin piece os sheetmetal
Old Sep 14, 2003 | 07:47 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I'm kind of curious if there's a 5th wheel hitch in the hatch
That, at least, makes me feel a little better about some the the questionable things I've made
Old Sep 14, 2003 | 08:23 PM
KiLLJ0Y
Guest
Posts: n/a
all you did was bolt a plate to the bottom of an aluminum trunk!
go ahead.. hook something up to it.. and watch your entire trunk bottom be ripped out.
tow bars are bolted/or welded to the actual frame of a truck. i get a good laugh when i see cars with tow bars. especially camaros, because they dont have a complete solid frame throughout the car. tow something heavy enough and watch it rip your car apart.
not to mention even if you "were" able to get something behind your car.. what do you think is going to happen if you need to put the brakes on even semi-hard?? what ever you're towing is going to crash straight to the back of your car. nice one man...
Old Sep 14, 2003 | 08:33 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
Actually if your read his post well enough you would see that it is not his car... As for the subframe issue you mentioned. A sub frame vehicle can actually haul a lot of weight if it is done properly. For instance... I have a 89 Safari Van with a class III Reese hitch. It in fact is a uni body and not full frame. I haul a 1500# trailer with a 3000# car on it. No problems ever!!!
Oh yeah the bottom of F body cars are not aluminum BTW.
Frozer!!!
Jan 19, 2024 04:55 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
two-if-by-sea
Exterior Parts for Sale
Sep 13, 2015 06:52 PM
Ozz1967
Aug 16, 2015 10:23 PM
NBrehm
Aug 5, 2015 07:57 PM
