Headliner Q
Old Oct 9, 2003 | 02:25 PM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Transmission: Worn-out 200R4
Axle/Gears: BW 9-bolt, 3.27's
Headliner Q
Good day.
My headliner is in great shape, having been replaced a couple years ago by previous owner. Only problem - it sags. Bad. Is there some tacky stuff I could purchase that anyone recommends? Plus, the liner is perfect conditon, I don't need to rip it out, and the foam above it is still good - they just came apart. I want to keep the liner intact, so telling me I need to rip it up to fix it is... well... not what I was looking for.
-The Husband
Old Oct 9, 2003 | 03:46 PM
si_camaro's Avatar
Car: 85 Z28
Engine: LG4 modified
The best stuff to use is 3M spray adhesive. If you remove your interior lamp you should be able to spray the whole of the inside of the headliner without removing the whole thing. Unless you have T-Tops, and then you're on your own!
Si
Old Oct 9, 2003 | 05:10 PM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Thank you! Nah, it's a regular roof, no worries.
Old Oct 9, 2003 | 07:26 PM
CaysE's Avatar
3M General Trim Adhesive or 3M Fast Tack Trim Adhesive will both be good for headliner. Good call with removing the lamp... I was going to suggest a heat gun to peel it off and do the whole thing over, which you may want to do unless you feel like repairing anything else that starts sagging in the future.
Do NOT use 3M spray Super 77 or 90! I'm willing to bet that's what was used to put your headliner on by the previous owner, and now you see the result.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
PurelyPMD
May 5, 2016 04:57 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
MORREALE5
Sep 13, 2015 09:01 PM
blackbmagic
Sep 8, 2015 10:36 PM
