removing tires from rims
Old Oct 12, 2003 | 01:49 PM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
i recently obtained a set of irocs that i plan on cleaning up, might sell, might put them on the trans am. the person i got them from decided to cut the tires off, but the sides are glued to the rims. anyone have any tips on how to remove the rest of the tire from the rim?
Old Oct 12, 2003 | 02:43 PM
nolanr0413's Avatar
Car: Trans am
yeah , take them to the tire place and pay them 20 bucks to take them off .
Old Oct 13, 2003 | 11:51 AM
Briansz28's Avatar
Mineral spirits, acetone (nail polish remover)??? Something to dissolve/loosen the glue- I never heard of gluing tires onto wheels but it makes sense to avoid spinning them.
Or cutting with a razor knife, loosening up a flap big enough to pull and yank it off?
Old Oct 13, 2003 | 12:11 PM
Diabolical's Avatar
Engine: 305HO L69
me neither, i just thought the stuff they put on is the seal them, i figured they used the tire pressure to keep the tire on the wheel. I've tried scraping it with a razor, and i've tried prying with a screwdriver, neither attempt was successful. i will try the acetone, see if that works, thanks.
Old Oct 13, 2003 | 12:15 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
It's really not worth the effort especially if it's glued on as well.
The bead of the tire has a laminated steel band in it (rougly ½" thick total width) and is 'pressed' onto the wheel. It requires a couple pry bars, WD40 and a really bfh (and a few choice words). There's a very good chance of gouging/ruining the bead seat (for lack of knowing what it's really called) using this method as well.
I have done this 1 time and 1 time only. Some tires shops (Pep Boys here) charge $0 to remove a tire.
Old Oct 13, 2003 | 01:38 PM
badandy247's Avatar
Car: 91 Camaro RS
Engine: 3.1L V-6
Transmission: Fresh 700R4
it's just bead sealer we use it all the time at work on cheap tires that don't like to seal well and you're not gonna get that tire off the bead easily if at all just take it to a local shop and offer a mechanic $10 under the table to pull em off for you it'll take him about 30 seconds per rim to do
Old Sep 20, 2005 | 11:30 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Is it bead sealer? I work at a shop and do a lot of tire work, I would do the work for free if you asked politely, so hopefully someone near you will.
Old Sep 21, 2005 | 09:06 PM
deadbird's Avatar
Engine: TPI 305/ v6
(Psst.. post is almost 2 years old)
Old Sep 21, 2005 | 09:46 PM
Car: 91 Camaro RS
Yeah, I was an idiot. I did a search for something and this came to the top. I forgot to check the date even. I wish there was a "go back and time and read before posting" button.
Frozer!!!
Jan 19, 2024 04:55 PM
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
Vintageracer
Jan 10, 2020 05:33 PM
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
3rdgenparts
Aug 8, 2015 07:09 PM
