custom 86 trans am spoiler options-origional is a mess!
Old Oct 28, 2003 | 01:36 PM
andys86ta's Avatar
Car: 1986 trans am
Engine: 300hp 355cu. inch
Transmission: 350 turbo with shift kit and ratchet shifter
Ihave an 86 TA with the wrap around wing, it looks nice but it is cracked and peeling (and also really heavy). No way of fixing it that I know of. I would like to here of some suggestions of spoilers from other vehicles that may have worked for other people. The after market cataloges don't suggest anything and don't have any measurements. thanks for any help.
Old Oct 28, 2003 | 03:30 PM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
Mine is the same way. It appears to have been white at one point as I sanded down a little portion of it to see what I had to take off to get it back to baseline.
I will try and take it down and then prime it next month. Definately use some flex agent in the paint.
Old Oct 28, 2003 | 08:12 PM
transambill's Avatar
Car: 91 Firebird Formula
Engine: ZZ4 fast burn with TPIS mini ram.
Transmission: Viper T10 6 spd.
Do a SEARCH. There's a ton of info on here on this topic.
Basically GM designers screwed up by letting our cars leave the factory with these junk spoilers. You can't put enough flex additive
in the paint,it will still crack. Your only alternative is to replace the factory one with a aftermarket one thats made out of fiberglass.
No rot no cracked paint and they weigh less than half that of a factory one. Or If you don't want to spend $300 + for a aftermarket you can do what I did and get a 91-92 style wrap around wing or a factory 4th gen style works with a little modifing.
Do a search on this board under spoiler and see what everyone
else has done.
Old Oct 28, 2003 | 08:14 PM
Badazz86z28's Avatar
Car: 88/Form 86/Z28 87 Trans
Engine: 305 TBI 305 Carb 350 TPI
Transmission: 700r4 x3
Fiero GT wing looks cool
Old Oct 28, 2003 | 10:07 PM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
I have a fiero GT wing and one with a light bar in it also.
They connect at a different location than the stock wing and have less surface area that then stock wing, and just a tad shorter than the stock one also.
Jim.
Old Oct 29, 2003 | 11:32 AM
Well im not one to be afraid of Drilling in to my car and everything so you might be talking to the wrong person My friend used a fiero Gt spoiler Made pedistils for it and drilled the sucker on. Im about to Get my 4th gen WS6 wing for my bird and I know thats not gonna fit with out fabing
LilHot
South Central
Apr 13, 2026 11:46 PM
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
