Head Rest removal
Old Nov 8, 2003 | 03:24 PM
Kleen RS's Avatar
Car: 92 25th Anniversary RS
Engine: A slow one. The infamous 305 TBI
Transmission: 700 R4
Head Rest removal
I am planing on swapping my seats over because the drivers side is all broke down. In order to do that I need to swap the head rests. Well, I can't figure out how to get them out. Anyone got any tips?
Old Nov 8, 2003 | 05:42 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Sure... get a long (12" or so) thin piece of metal or plastic, about 1" wide. Move up the headrest, slide the piece of plastic or what ever your using down the front of the headrest post into the seat as far as it will go. Now, hold the piece to the post, and push the headrest down. Holding the piece down and inplace inside the seat, pull up on the headrest, and out it will come!
Good luck.
Old Nov 8, 2003 | 07:01 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
put your back on the part you sit on, put your feet on the head rest and kick the biatch outa there. Just make sure that when it coem out you dont kick one side more than the other cause it will hit your leg and cut you. But its easy enough. maybe you can wear some pants and it wont cut you though. this is what i did.
Old Nov 9, 2003 | 07:02 PM
Need4Speed1387's Avatar
Car: '86 IROC
Engine: 305 LG4 awaiting the crate Vortec 350
You must be pretty short cause i don't think its humanly possible for me to lay like that while inside the car!!! then again im 6'4"
Old Nov 9, 2003 | 07:25 PM
Red90IROC's Avatar
Car: 1991 Trans Am
Engine: 5L TPI
I'd suggest following 88WS6's advice. I got mine out the hard way and it bends a clip pretty bad if you use brute force. Using 88WS6's method nothing gets damaged.
Old Nov 9, 2003 | 07:40 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
well i'm onyl 5'10" so i could fit.
Old Nov 10, 2003 | 03:57 PM
justadba's Avatar
Car: 88 IROC convertible, 88 Sport Convertible---both RED
Engine: 350 TPI in the IROC, 305 TBI in the Sport
Transmission: 700R4 in both
88WS6 has the right approach. I redid my seat covers and that's the method I used to get mine off.....came off easily and in @ 10 seconds....no pain, no agony, no messed up parts
Frozer!!!
Jan 19, 2024 04:55 PM
camaroken83
Aug 10, 2015 11:35 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
