HVAC help
Old Nov 15, 2003 | 06:21 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
HVAC help
just bought my new camaro and i noticed that it only blows out of the defrost vents. why is that i would like them to blow out of the normal heater vents and such if it is fixable.
Old Nov 15, 2003 | 06:55 PM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
one of the vaccuum lines isnt hooked up. had the same problem on my 91z. the line was connected at the engine, and everything inside was ok too. i pulled the line off the plenum and blew into it heard it pissing out behind the block. looks like the hard plastic lines snapped, it was an easy fix. Hope this helps.
Old Nov 15, 2003 | 09:28 PM
92MaroRS's Avatar
could you possibly go into a little more detail and maybe if ya got any pics of where to look? also it hisses constantly when its in any other position other than off.
Old Nov 15, 2003 | 10:12 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Since not everyone is graced with a TPI, I'll describe the area for a TBI.
All hvac controls draw their vacuum from the motor to operate.
The TBI vac. line is located under a bunch of crap near the rear of the intake (white arrow shows where mine is). It 'T's off to a vacuum reserve canister but, the main part goes through the firewall to the gauges (located generally where the yellow arrow is pointing).
If for some reason the lines are bad under the hood, there will be no vacuum to operate the servo's for your hvac.
Another problem area is the vacuum selector on the backside of the hcav controls. Over time, the seal can wear out causing the selector to develop a leak or, as with mine, the tab that connects it to the vent selector broke.
TPI works the same way but, the vacuum line is routed to the TB at the frnt to the plenum.
Old Nov 16, 2003 | 11:03 AM
92MaroRS's Avatar
could this be why it hisses constantly unless in the off position?
Casey Meyers
Mar 2, 2016 10:46 AM
777Shock777
Oct 29, 2015 04:30 PM
timonator
Sep 30, 2015 12:52 PM
Chevykid810
Sep 28, 2015 12:57 PM
Eric-86sc
Sep 28, 2015 11:37 AM
