window slop/missing part
Old Dec 2, 2003 | 12:48 PM
Marlow55686's Avatar
My driver's side window has been rattling excessively for a long time. I finally pulled the door panel off to adjust the guides along the top. However, the guide further away from the hinge was already to the max and there is a hole in the window where some white plastic/nylon piece is suppose to go. I don't know what this plastic piece is called or if it still available. I would like to fix this soon as the guide is tearing apart the tint film. Any help where i could get this part will be appreciated.
Old Dec 2, 2003 | 01:16 PM
Screamin'87GTA's Avatar
Car: Trans Am GTA
Transmission: Rebuilt 700r4 with stage 3
I think we all will eventually run into the same problem..
Pep Boys sells them in there "help section" I think they are labeled window shims.. The pep boys near me closed before i could get some... Let me know if you find them.
Old Dec 3, 2003 | 02:07 PM
Went to advanced auto parts last nite and they had nothing like it. I tried Pepboys today and they had many nylon fasteners/rivots/bushings but the window type either wasn't in stock or they don't carry it. However I found something called "Magic Sliders" at Home depot in the hardware/coaster section. They are grey disks(teflon?) meant for putting on furniture feet to help them slide. I got the 2 inch size(50 mm) and stuck it on the hole in the window and adjusted the top window adjuster, rolled up the window and no more vibrations. note that the 2 inch disks may be too big and 1 inch will prolly work
Old Dec 3, 2003 | 07:11 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You can sometimes find them at auto glass repair shops. I got one there and picked up several from a local junkyard off windows that had been broken. Just had to drill out the rivet holding them in and then gently pry them apart.
The Trickster!!!!!!!!!!!!!
1992 Trans Am
May 10, 2023 07:19 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
