change gauges
Old Dec 2, 2003 | 01:49 PM
Kingdomofmadnes's Avatar
Car: Camaro z-28-1992
Engine: 305tpi
Transmission: th700r
change gauges
I have a camaro z28-1992,and i want to put some white gauges in my car,but how do i do to remove the gauges from the dashboard,its seems to be harder then the old camaros beacouse i dont find any screws in my modell
Pics would be great
Old Dec 2, 2003 | 08:40 PM
stiers's Avatar
Step 1: Go to the Auto Parts store and get a Haynes Manual. Everyone should have some sort of shop manual for their car.
Step 2: Open the book to the interior section and find the part about replacing your guages.
Incase you missed step 1 I will tell you how.
First you need to remove the trim ring with the cig lighter and headlight switch. To do this you need to first remove the headlight ****. Take out the blank plate under the ****, shine your light in there and at the bottom of the headlight asembly there is a pin with a spring on it. Pull out so the headlights are on, then push in the pin and the **** and shaft will come out.\
With that out of the way you need to take off the lower dash cover. I believe they are torx bits. Once that is off you can reach the 2 bolts that hold the plastic trim off. Remove those and disconect the cig and defrost wiring.
Now you should be able to see the bolts that hold the clear plastic onto the actuall guage cluster. Since you are just doing white faced and not glowing you wont need to pull the cluster out. Just undo the screws that hold the clear plastic and maybe 2 more that hold the grey trim on and you can install your white face guages.
Old Dec 2, 2003 | 09:22 PM
badandy247's Avatar
Car: 91 Camaro RS
Engine: 3.1L V-6
Transmission: Fresh 700R4
step 3 kick yourself in the junk for buying the haynes manual
Old Dec 2, 2003 | 09:46 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Old Dec 3, 2003 | 07:10 AM
Engine: 305tpi
Thanx for the helps guys:hail:
i have learn so mutch now,maybe im gonna ask you more
about step 1 and 2,if i got problems on the road when had to walk to the local auto parts store
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
355sbcTPI
Aug 19, 2015 04:38 PM
ChevyZ71
Aug 13, 2015 07:30 AM
