noisy headlight motors
Old Dec 7, 2003 | 02:20 AM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
has anyone ever found a fix to quiet the extremely loud 82-84 headlight motors? Do newer ones convert over?
Old Dec 7, 2003 | 10:51 AM
Agent13's Avatar
Car: 1983 Daytona Trans Am
Engine: LG4
I would like to know this too.
Old Dec 7, 2003 | 02:19 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
It shouldn't be too dificult to upgrade to one of the 'newer' styles; you'd need the motors themselves and the correct underhood harness to operate them.
I think you would have to remove the headlight mechanism to swap the motors, so you'd need to mark the position of the mounting bolts before removal to easily re-align it after changing motors. You can disconnect the harness at the bulkhead connector on the firewall and install the new one. The switch and other wiring should be fine.
Pete
Old Dec 8, 2003 | 01:25 AM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
ttt
Old Mar 24, 2011 | 12:36 AM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: noisy headlight motors
OOOOLD thread, but I didn't want to make a new thread if one allready existed.
Anyone have a fix for this? Mine sound like rubber rubbing on metal with a loud annoying noise. My 84's headlight motors sounded the same also.
Old Mar 25, 2011 | 10:30 AM
Firebat's Avatar
I don't know if there is a fix but I would see if they can come apart, clean them up, and re-grease them with maybe that purple marine style grease. I think top down solutions might sell new gears but I don't for sure on this either. That's where I would start.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
GTAman
Mar 15, 2019 11:40 AM
LittleFranks
Sep 17, 2015 12:22 PM
stalkier
Aug 13, 2015 12:59 PM
