Quation on Headliners
Old Dec 14, 2003 | 12:34 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
What did you guys use to cut the holes for your overhead consoles? My new headliner is made out of plastic and is covered in fabric.
I want to do this right without cutting it all up. Thanks.
Old Dec 14, 2003 | 01:15 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
i used a good sharp utility knife and went real slow. i cut from the plastci side taking care not to cut any material until i was ready to cut it. when i got the plastic out i cut an x in the material and taped back the material to help hold it tight.
Old Dec 14, 2003 | 03:16 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Jeff is right on. just dont try and cut right thru the pastic. scrivbe the plastic . this will keep you from slipping and making a mistake cut.
Old Dec 14, 2003 | 07:36 PM
87WS6's Avatar
That is actually a really good idea. I never considered that. Thanks.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
PurelyPMD
May 5, 2016 04:57 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
MORREALE5
Sep 13, 2015 09:01 PM
blackbmagic
Sep 8, 2015 10:36 PM
