For those who have the ASCD 4th gen SS hood
Old Dec 17, 2003 | 12:00 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
is there anyway to attach insulation to the underside of this hood?? and does this hood come primered??
Old Dec 17, 2003 | 11:38 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I'm sure there could be away to attch insulation if you wanted to...as far as primer goes....no, it's not primered. There is a layer of gel coat applied to the hood, which has to be sanded down, then primered. Gel coat will withstand weather conditions, it's a pretty durable coating.
Old Dec 18, 2003 | 09:40 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
What about that front grill does it function by letting air into the engine bay or is it just for looks??
Old Dec 18, 2003 | 09:42 AM
Engine: 5.7
It is a functional grill, it lets air into your engine bay.....BUT there is no air box for actual "ram air".
Old Dec 18, 2003 | 08:24 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
does it work fine with the stock hood struts or do you run the risk of cracking the hood?? Meaning are the struts too stiff for the hood??
Old Dec 19, 2003 | 07:58 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I have the ASCD Big Block hood and it bolts on with the stock struts and shuts fine. It is a little hard to close but not hard enough to crack the hood.
Old Dec 20, 2003 | 08:05 AM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
if you're really worried about it, go to the auto parts store and get struts for an 82-84 z28 with a fiberglass hood.
Old Dec 20, 2003 | 08:12 AM
nolanr0413's Avatar
Car: Trans am
i run the 82-82 camaro with fiberglass hood struts. THey work perfectly. i have an ascd ram air 2 hood. they cost about 70 bucks from gm .
Old Dec 22, 2003 | 11:00 PM
AC's Avatar
AC
Car: Used to drive a camaro
I just bought the ascd ram air hood about a month ago. I've already started filling in the gap that runs along the enitre parameter of the underside where the bottom and top halves meet. I've also enlarged the underside air inlet and layed down some fiberglass mat to create a wall so that air will not go into the cavity between the two halves. I can post pictures if people want to see how I'm approaching it all. By the time I'm done I should have a hood that actually looks MUCH better than stock and actually has ram air (yes I'm designing a ram air box)
Old Dec 23, 2003 | 01:51 PM
FLYNLOW92rs's Avatar
Excuse my odd question, but why would you want to attach insulation to the underside of the hood?
Old Dec 23, 2003 | 02:17 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
just bought some for my '82 for 30 bucks at autozone
Old Dec 23, 2003 | 08:40 PM
WishIHadAZ's Avatar
Car: 87 iroc
Engine: L98 350
Something I've always wondered - if air can go in, then what about water? Hydro-lock is bad no?
Old Dec 24, 2003 | 06:53 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
I want insulation cause I don't want engine heat to ruin my new paint
Old Dec 24, 2003 | 07:05 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
What gap ar you talking about AC?? Post some pics of your project
Old Dec 24, 2003 | 08:47 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
you would have to have some serious problems for the engine heat to damage the paint on your hood.
Old Dec 24, 2003 | 08:59 PM
Kandied91z's Avatar
i've been running my car without insulation since it was painted candy.....sill winning shows. don't worry about it, now if you want it for looks that's a different story although mirrored plexi looks better.
Old Dec 25, 2003 | 01:06 AM
AC's Avatar
AC
grafx,
here's (2) shots of the "gap" and the fiberglass filler I'm layin in.
Old Dec 25, 2003 | 07:51 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
thought that was the whole reason cars came with insulation under the hoods. Other than to quiet engine noise I thought it also served to keep too much heat from affecting the paint. Anyways thanks for the info
Frozer!!!
Jan 19, 2024 04:55 PM
Warlocksirix
Sep 3, 2015 12:26 PM
cam-mike
Aug 24, 2015 07:23 AM
