Bondo job -- new paint job...
Old Dec 21, 2003 | 05:24 PM
CbrasTsteLkChk's Avatar
Car: '84 Camaro SC/ I-ROC Body Conversio
Engine: Rebuilt 350 5.7L, Edelbrock 750cfm
Transmission: Re-built 700-R4
Axle/Gears: Moser, 3.73
I'm planning on getting a new paint job. My concern is i did a pretty large area of bonding inbetween the front driver's side fender, back half, and the driver's side door, as well as over on the passenger's side front fender near the sidemarker. When i primer this area will the bondo chip, break apart, and fall off?!?!
Might i want to replace the front fenders and the driver's side door before getting it painted or what?
Old Dec 21, 2003 | 05:56 PM
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
It shouldn't have any problems, provided the surface was prepped right, and you have done all the steps. If you had to do quite a bit of body filler. Then sure why not.. if you can get replacement panels that are in good shape. Other wise I wouldn't worry to much about it.. Body filler is a fact of life on a car when you are working on it.
Old Dec 22, 2003 | 09:42 PM
yeah i definetly took the time to do the bondo job right and was very meticulous about it looking "perfect" for my liking.
Old Dec 22, 2003 | 09:53 PM
87z28camaro's Avatar
Car: 1987 Z28 Camaro
Engine: 305 tpi
well i've seen some people bonda a car, and it looked damn good when finished and lasted, but i've seen others that done it and looked like crap, like they stated above, if you done the prep work right then you shouldnt have to worry, unless u like used 30 pounds of bondo, then i'd be worried
Old Dec 22, 2003 | 10:03 PM
You tell me what you think of my bondo job:
It was about 1ft. 1/2 long between the drivers side fender and the crack of the driver's side door.
MY CAMARO --- BONDO JOB
Hotrodboba400
Dec 10, 2019 07:07 PM
m00n420
Sep 11, 2015 02:39 PM
rsrookie
Sep 5, 2015 07:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
