power windows to non power windows
Old Dec 28, 2003 | 08:19 PM
ejm's Avatar
ejm
Car: 83 Black T- top Firebird
Engine: Carbed 350
Transmission: 5 speed
hey i have a 83 firebird and want to get rid of the power windows and put in hand crank ones. is this possible and can i buy kits from anywhere. thanks, Eric
Old Dec 28, 2003 | 11:06 PM
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
I actually did the swap from manual to power.. so What I would recommend it check out some of the local yards for the manual window regulator and some handles.. it's a direct swap when you remove the power regulator.. then all you need to do is cut a hole in your door panel, and your set.
Old Dec 29, 2003 | 05:24 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
hey, um... aboutr those power windows????
i would be intrested in converting my right window to power since i cant reach it.
do yours work, can i have em/ buy em. PM me or post here or email me .
thanks.
oh yeah about your question, finding the handles is going to be the hard part. when you go to take them off they will seem to seem to be quite stuck to the door, just pull hard, there is this clip on the back, if your lucky you wont break it, i have only done this once and it was on a corrola, oh, i take that back, my charokee they just came right off. good luck
Old Dec 29, 2003 | 08:06 PM
ejm's Avatar
ejm
Engine: Carbed 350
no my windows don't work that is why i want to swap them. it is pretty embrassing pulling up then trying to roll down the window with it cluncking and schreeching and moving as fast as a snail. About what fast electics (sorry if i spelt it wrong) said with the power regulator, not sure what that means but if it means the motor then you can get a new motor from 1aauto.com for $40 then it would be a direct swap except for needing wires and a switch. i see you need v6 headers. did you ever find any and if so where? Do they have the AIR system or what ever it is called on them? thanks, eric
Old Dec 30, 2003 | 12:26 AM
Car: 89 Camaro RS
Engine: 305 TBI
90 % of the time when a power window appears to be failing, it's because the regulator pivot points are starting to stiffen up.. I found it helps a lot to keep those points lubricated.
Take a look here.. this should help clear up some of your questions too.. Plus what you want to do would be the opposite of what this tech article is showing.
http://www.p71interceptor.com/thirdgen/powerwindows/
1992 Trans Am
May 10, 2023 07:19 PM
jhawkeye
May 25, 2022 06:33 PM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Aug 24, 2015 10:11 PM
stalkier
Aug 21, 2015 01:54 AM
