speedo question
Old Jan 3, 2004 | 04:41 PM
89cmrodriver's Avatar
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
speedo question
I just got a 91 RS today, and the speedo doesnt work, the guy i got it from said it works sometimes and not sometimes, and i can see that it has worked since the inspection was done. What could be wrong? and if possible please provide pics of what you are talking about, and some help as to how to get the gauge cluster out. (im new to this style dash)
Old Jan 3, 2004 | 08:15 PM
Transmission: autos
come on guys. wanna do this tomorrow when i do the rest of the repairs
Old Jan 3, 2004 | 08:45 PM
Leahs88irocz's Avatar
Car: 1988 iroc-z baby! :o)
Transmission: soon 2 be replaced.
my speedo hasnt worked since i got my car....
u might wanna try the cable....and just to let u know......u cant pull the needle off!
(now i gotta buy the whole thing and the cable)
Old Jan 4, 2004 | 10:48 AM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
look at the tailshaft / tail-end of your transmission on the drivers side, if it has wires that plug into the transmission it is a eletric speedometer. It is a cable driven speedometer if it has a pencil thick cable going into the transmission. If its electrical chances are the easy fix is to check the plug, wires and other connections. If it is cable driven, chances are you will need to remove the cable, run a little oil/trans fluid through it to lube the cable and check if the speedometer is worn out, try and spin the backside of the speedometer housing and see if the needle still moves, if not the speedometer is junk ( you will need the speedo out to try this) good luck
Old Jan 4, 2004 | 11:23 AM
CALIROCZ28's Avatar
Car: '98 Z28 LS1
Transmission: 4l60E
Axle/Gears: 373
If you have a '91 then you'll have a VSS at the transmission where the cable goes into the trans. Check it to make sure it is tight and snug. If it is ok check the other end of the cable going into the back of your cluster.
Old Jan 4, 2004 | 04:03 PM
Transmission: autos
i checked the plug, and pulled the dash apart to look at the back of the speedo, couldnt see anything, im gonna take it to a local dealer to have it fixed
Eric2ndGen
Nov 5, 2015 01:51 PM
stickychinsac
Aug 31, 2015 06:06 AM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
redmaroz
Aug 16, 2015 11:40 PM
beachrodder
Aug 7, 2015 04:27 PM
