Car was hit in a parking lot, what can be done to fix it
Old Jan 12, 2004 | 02:42 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Thursday when I came to my car after school, I noticed a dent with about 1 foot diameter in the left rear quarter behind the wheel and under the gas cap. I also noticed their is a crack in the front bumper with some scratches and scuff marks. I don't have collision, and they don't have cameras in the parking lot. So I don't think I'll ever know who caused the damage. The paint job was done in 2000 and was 3600 bucks. My dad estimated the damage at $700 bucks.
Because I have very little money, I would like to know if their is any way I could fix the dent myself. Are you able to hammer from the inside in that area?
Old Jan 12, 2004 | 03:04 PM
Pepsicola's Avatar
Engine: 305 TBI
Transmission: 5 spd
Axle/Gears: 10 bolt w/eaton posi 3.73
Hey whats up Lance.... got any pics of it??? Sorry to here about that. I may have a buddy that can help you out.
Old Jan 13, 2004 | 02:32 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
I'll have pics tonight. Tell me more about your buddy.
Old Jan 15, 2004 | 12:29 PM
Pepsicola's Avatar
Engine: 305 TBI
Transmission: 5 spd
i sent ya a pm y0
Old Jan 24, 2004 | 05:19 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
I finally got the pics back. Here is the damage done to the front bumper. You can see the crack on top, and the white scratch in the middle.
Attached Thumbnails Car was hit in a parking lot, what can be done to fix it-front-bumper-damage.jpg
Old Jan 24, 2004 | 05:22 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Heres a pic of the left rear q panel dent.
Attached Thumbnails Car was hit in a parking lot, what can be done to fix it-left-rear-q-panel
Old Jan 24, 2004 | 05:24 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Heres another pic of the dent. You can see the reflection of the garage right above it.
Old Jan 24, 2004 | 05:51 PM
onebinky's Avatar
I'd go walk around your parking lot and look for cars with damage that matches up to your damage, then look for paint transfer between your car and her's (just a guess on the sex)
Then get the cops involved and see what they think...
Old Jan 24, 2004 | 06:05 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Theirs not paint transfer on the dent, but their are white scuff marks. That may be the clear coat scratched off, or from a white or grey car. Because their was damage in two different spots, it leads me to think it wasn't a car.
Old Jan 24, 2004 | 06:22 PM
Pepsicola's Avatar
Engine: 305 TBI
Transmission: 5 spd
Almost looks like it could have been done by a snow plow or something like that, in the second pic...
Old Jan 24, 2004 | 07:43 PM
benoit454's Avatar
Car: 86 camaro
Engine: 2.8 multiport cross fire injection
Transmission: 5 speed
it can be fixed i dunno about gettin to it fomr inside but takin and rillin holes and usin dent puller or slide hammer same thing, would pull the dent out.
and for crack glue it together w/ seal all or epoxy or plastic cement or glue that should work then fill it over w/ bondo or something
might b possible to just fill it good w/ glue and smooth glue out n primer n paint it
white scratch may sand out if it didnt tear thru yur paint.
if so sand it smooth well smooth otu edges then repaint it.
and i know its expensive but i got a point on that.
instead of gettin hole car done u could just do a 1/4 panel and front bumper or even less n cheaper....
go to body shop supply store if ya can find one near ya.
have em mix u the paint to match yur car in a spray can!!
yeap spray can i know ppl dont beleive in thsi maybe but trust me it works!!!
bout 15 a can here
its pure automotive paint but has propelant in it to make it aerosol paint.
itll look just like original and match close to if they mix it right.
then just spray areas ya need and take let dry , litely wet sand w/ thousand grit or finer and use some rubbin of buffing compound to buff it and that will get rid of the dry lookin dull spots.
and look good again.
weve done that many times on dads s10
due to rust spots and accessories added.
Old Jan 24, 2004 | 08:13 PM
copperhead110's Avatar
You should be able to get to the back side of that dent. You'll have to remove some of the plastic panels in the hatch. For a temporary fix, you might be able to pop the dent out by pushing it out from the inside. It probably won't fix it completely but it might make it look better.
Old Jan 24, 2004 | 08:44 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
havent tried it but what about that hot glue thing the sell on tv the dent poper or something like that might get the rear if you cant get behind it. The front looks like someone kicked it or put there foot on it leaning on the front.
Old Jan 24, 2004 | 09:41 PM
benoit454's Avatar
Car: 86 camaro
i remembered a lil backyard secret n dont laugh it works great use a toilet plunger!!!!
it will pop out some dents but ones thats creased it prolly wont but it works fine on alot of em.
just make sure its clean 1st lmao
Old Jan 24, 2004 | 09:47 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Would that work on a dent this big? I think I would just buy a new plunger first.
Could I do any damage trying this?
Old Jan 24, 2004 | 09:53 PM
benoit454's Avatar
Car: 86 camaro
nope wouldnt think yud do any damage
we had a tire bounce being thrown otu back of truck n hit 1/4 panel put dent in it grabbed plunger and popped right out.
yurs was right on crease tho so might not do that well
u cna try tho also auto parts stores sale a lil hand held type plunger for doin this
go check that out over were bondo n stuff is
that might b even better but i dunno
u gotta push plunger down good nto hard enough to make new dent but u know get good bond then pull like hell just watch it comes loose u gonna be fallin prolly lol.
worth a try only other thing might do is pull it w/ slide hammer
also seen posted on another thgin bout dents
diy bodywork i think
guy said if dont got a slide hammer can drill hole put in sheet metal screw or a screw n pull the screw w/ pair of pliers to pul it so that may work 2.
Old Jan 24, 2004 | 09:54 PM
benoit454's Avatar
Car: 86 camaro
after lookin at it again i think yea plunger may bring it out somewhat at least help ya to get it out more
may even bring whole thing out
id go for it
Old Jan 24, 2004 | 10:04 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
I don't want to drill any holes. I'll ask around about the plunger idea.
Old Jan 24, 2004 | 10:07 PM
benoit454's Avatar
Car: 86 camaro
id try the plunger thing tho i think it would work
Old Jan 26, 2004 | 01:03 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
I can't imagine a plunger helping that damage. it's creased! I'd bring it to a body shop for an estimate and if it's way over what you can afford, ask if there are any less expensive ways to go about repairing it. if it were round and just pushed in, you may be able to pull it out but not with a crease like that.
Old Jan 26, 2004 | 07:06 PM
benoit454's Avatar
Car: 86 camaro
ive used plunger one worse and yeas it wont completely fix it like i said it may work may not since creased.
but it will bring dent out more to make ti easier to pull and less bondo
Old Jan 26, 2004 | 07:09 PM
DJsyclone's Avatar
I'm going to call my body shop and ask what kind of plunger they use.
Old Jan 26, 2004 | 07:13 PM
benoit454's Avatar
Car: 86 camaro
they might laugh at ya its kinda an untold trade backyard secret and it works.
auto stores sale a palm type one but a regualr old toiler plunger works better then the rest
Old Jan 27, 2004 | 01:52 AM
burroughs's Avatar
Car: NONE! and it SUCKS!
damn, Your car looks good, too... This is why you always get collision. idiots will always find and hit the car without.
Old Jan 27, 2004 | 06:57 AM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Because I'm 16, its like 400 a month for collision. I've had my license for 5 months, so the damage wouldn't have paid off. My insurance is already 4 dollars and some cents a day. Thats without any accidents or tickets.
Old Jan 27, 2004 | 11:16 AM
stiers's Avatar
That has got to be the most ******* halfassed way to fix a dent I have ever heard of. I dunno if I would trust a guy whos car is all primer to give bodywork advice.
Old Jan 27, 2004 | 11:47 AM
benoit454's Avatar
Car: 86 camaro
Old Jan 27, 2004 | 01:25 PM
stiers's Avatar
Hey, don't get too upset. My car is completely in primer(black) too. It was more of a joke. I tried that TV puller and it didn't work for crap on any of my dents. I just had to laugh imagining someone on the streets putting a plunger on his car and pulling. He spend $3000 on a paint job a few years ago so I figure he isnt looking for an easy out.
Old Jan 27, 2004 | 01:48 PM
benoit454's Avatar
Car: 86 camaro
ok lmao shoulda said something lmao i didnt know yurs was too lmao im sorry lol i get hot headed rednecked easy lmao
but yea man most ppl have same response to that they like huh?
a plunger?
thats stupid lmao
but it does work
on some dents lol not all
i just thought he might want the cheap tip.
man i wont have that much money in my whole car tho that 2or 3 grand u said he paid for paint job.
at most got 500 in car
bout 500 maybe in supplies n stuff i need
and 500 in wheels and 500 in tires
maybe another 500 in inerior stuff maybe
thats expensive lol
my paint and all the stuff to apint my car wont be more then 500
thats paint, reducer,masks for paintin,hardner,flex agent stuff,
and quart of black for my stripes and the reducer for it.
i couldnt seen given that much for paint job but if ya cant do it yaself n want it done right i guess it would be ok to pay that price.
Old Jan 27, 2004 | 05:38 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
My sister paid for the paint job when she owned the car.
Their was a crack in the paint afterwards, and I chipped it off and covered it with primer. Will normal winter driving affect the primer, or should I cover it with paint soon?
Old Jan 27, 2004 | 06:12 PM
benoit454's Avatar
Car: 86 camaro
hmmm
i heard somewere that spray can paints or primers one wont seal out water to avoid rust so i dont know.
if it was me id leave it alone if u plan on painting soon but if not then id go on paint it so it match car better.
but just keep in mind when u do paint it w/ rattle can itll have be taken all off to the primer before it can be done w/ automotive grade paint or itll crackle and junk.
automotive grade meaning from spray gun
Old Jan 27, 2004 | 06:37 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
I used a spray can of rust-o-lem(think thats how you spell it), then sprayed it on to a piece of newspaper. Then I took a small brush and put it on.
Old Jan 27, 2004 | 07:09 PM
benoit454's Avatar
Car: 86 camaro
u just brushed on primer?
or u mean u done paint that way?
ive done that before tho take spray the paint in the lid take brush and paint it on mostly for custom lettering and stuf tho
but actualy if it cracked thats prolly best way u coulda done it since brush will fill in more then sprayin it in would
Old Jan 27, 2004 | 07:24 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Thats how I put the primer on.
Old Jan 27, 2004 | 07:56 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Wow, you're car is nice! I still can't find the damge in the 1st pic... but then again I've never owned a 3rd gen that was mint like yours!
Old Jan 27, 2004 | 09:33 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
lol it's far from mint. Daily driven with 78 thousand miles.
If you look at the top right part of the bumper, you can see the crack. And in the middle you can see the white scratch.
Old Jan 27, 2004 | 09:44 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
78k? Oh no! Trust me, that's mint compared to my 198k
BRoss99
Aug 10, 2025 05:08 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
TheExaminer
Aug 26, 2015 04:59 PM
86IROC112
Aug 17, 2015 02:00 PM
kyleb24
Aug 15, 2015 08:24 AM
