4th gen P/N
Old Jan 17, 2004 | 12:49 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
4th gen P/N
I need to see if anyone has the part numbers for the 5/6 speed shifter boot for the '01ish T/A or Camaro center consoles. I also need the P/N for the little cubby hole area up near the front of the console.
ANYONE?
Old Jan 17, 2004 | 12:51 PM
GTA4ME's Avatar
Car: 1988 Trans Am GTA Notchback
Engine: 305ci, 5.0L, TPI, HO
Transmission: Borg Warner T5 5-Speed
Axle/Gears: 9-Bolt Positraction Rear w/3.45 Grs
Check here.
http://www.newgmparts.com/
Old Jan 30, 2004 | 06:12 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
Can't find anything of use really on that website. Can anyone check their 4th gen 97+ console for the cubby p/n?
Old Jan 31, 2004 | 11:58 AM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
No one??
Old Feb 2, 2004 | 06:43 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
Out of all of you here with 97+ 4th gen consoles, ONE OF YOU, has to have the P/N's I need.
Old Feb 2, 2004 | 07:03 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Probably 2 reasons for that.. not many are going to rip apart thier console to grab a p/n and/or, not everyone is lucky enough to have access to a collsion guide or similar OEM catalog.
That said... my guide book only goes to 95 (because it's that old..) and the manual shifter boot for a 93-95 console (bird) is 17997789, camaro 17997785. I don't know what the difference is or if they are differnt from the newer models. That's the best I can do for you.
Your next option is to actually do some leg work and go to a dealer and ask them to look it up on the computer for you. You can also call a body shop, frame shop or some paint supply houses. Most all carry some form of a Motor collision guide book or probably now, it's in cd form for computers.
That's the best info I've got for you and you've gotten so far. Good luck in your endevor, hope that helped.
Old Feb 5, 2004 | 04:21 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
I went to the dealer today on lunch and got 2 part numbers. I had gone there once before and they refused to give out the part numbers.
The two part numbers are
10271369 - SHIFT BOOT/RETAINER
10411278 - COMPARTMENT
I checked gmpartsdirect but as usual, they want over $12 to ship something that combined probably weighs 1/2 a pound!
I'm probably just gonna pay dealer prices (which are only $8 total less than GMpartsdirect) and get them by Monday.
1992 Trans Am
May 10, 2023 07:19 PM
New2Chevy
Sep 28, 2015 12:35 AM
greenyone
Sep 2, 2015 03:39 PM
cam-mike
Aug 24, 2015 07:23 AM
