Small rust holes in the floorpans....
Old Jan 17, 2004 | 10:06 PM
Need4Speed1387's Avatar
Car: '86 IROC
Engine: 305 LG4 awaiting the crate Vortec 350
I took out my carpet yesterday and noticed that the drivers side floorpan has a couple little rust holes in it. They're no bigger than a dime each. How could i repair this? I'm going to POR-15 all the floorpans but how should i rid of these holes first? I really don't have access to a welder right now but would that be the only solution?
Thanks for any help!!
Old Jan 18, 2004 | 11:13 AM
qiker's Avatar
Car: 1989 trans am gta
Engine: tpi 5.7
It all depends on what you want to do with your car..If you want to keep it then I would suggest cutting out all the rot holes and welding in patch panels and por-15 it all ..That would last the longest..If you just want a quick fix then take a drill and get a copper cleaning wheel and scuff up all the rust spots then por-15 all the bare metal then get a good quality body filler and fillin the holes ..........Good luck dude.........
Old Jan 18, 2004 | 12:05 PM
Car: '86 IROC
I would like to keep the car for a real long time, but no way can i afford new floorpans or anything. For now i guess i'll just por-15 it and then eventually get it fixed right at the body shop. thanks for the help
Old Jan 18, 2004 | 01:38 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Clean real good, cut a metal patch (steel) and JB Weld it in. Smooth it out after it dries, then a good coat of paint.
Old Jan 18, 2004 | 05:59 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I had a serious rust problem along the seem in the driver's side area (6 inches x 1). I cut it out, used Por-15's mesh, putty, and paint about three years ago and the 'fix' still looks great. With problems so minor, don't (at least at this point) consider anything too radical.
JamesC
Old Jan 18, 2004 | 07:45 PM
87z28camaro's Avatar
Car: 1987 Z28 Camaro
Engine: 305 tpi
i had the same proble, i had it temp. fixed, so i just had them patch it, just because i didnt want my carpet soaked when it rained,
Hotrodboba400
Dec 10, 2019 07:07 PM
my86bird
Oct 23, 2015 12:20 PM
Jorlain
Oct 8, 2015 01:57 AM
mrdevontay
Sep 2, 2015 08:04 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
