Heat & A/C vents
Old Jan 22, 2004 | 11:05 AM
78camaroz28's Avatar
Car: 2001 Trans Am WS6
Heat & A/C vents
Anyone have any experience with their heater/AC not directing air to the dash vents or floor? All of a sudden I only have air thru the defrost vents in my 92 RS. They worked prior to a recent engine change, but all my vacuum lines are connected to their original locations.
Any suggestions are much appreciated.
Old Jan 22, 2004 | 12:47 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I had the same thing happen in my Beretta. Turned out to be a vacuum line I'd missed when checking earlier.
Old Jan 22, 2004 | 12:52 PM
kanuck's Avatar
Car: 1982 Trans Am
Engine: 350 Crate
Transmission: TH350
Yep, sounds like your vacuum line is not hooked up properly. Maybe it got put in the wrong place and melted after your engine change.
Defrost is the default air position when the system doesn't get any vacuum.
Old Jan 22, 2004 | 02:24 PM
87z28camaro's Avatar
Car: 1987 Z28 Camaro
Engine: 305 tpi
when i first bought my car i had that problem, it was the vacume line,so more than likely that is your problem
Old Jan 23, 2004 | 12:56 PM
The leak must be at the controller then. Everything on in the engine bay is connected to the correct location.
Old Jan 23, 2004 | 03:28 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Do you hear a hissing from behind the controlls? If you do its a vacuume line back there. I had the same problem.
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
