92 gauge cluster question
Old Jan 22, 2004 | 09:59 PM
firedawg225's Avatar
Car: 1992 Camaro RS
Engine: 383 w/Holley Stealth Ram
Transmission: Pro-built 700R4
I have a 1992 camaro my tach doesn't work and the trip odometer take 5 ot 6 puhes to get close to 0000. GM want $179 just to look at not counting any work they do. anyone know a cheaper place or how i may be able to fix it?? thanks
Nick
Old Jan 22, 2004 | 10:49 PM
85IrocNOH's Avatar
Car: 85 Iroc-Z
Axle/Gears: 10-bolt 3.42
just go to a junkyard and get another guage cluster. the 110 mph guage clusters are a dime a dozen. shouldn't be too expensive.
Old Jan 22, 2004 | 11:13 PM
Bandit5's Avatar
I changed my cluster form the crappy 115 to a 145 that I bought on Ebay for $200, then bought a new bezel for $60 on TGR. It was worth the cost. And since you will be getting a 350, it wouldn't hurt to actually know what speed you are at sometimes.
Old Jan 22, 2004 | 11:16 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
i dunno it could help, but who knows
Old Jan 23, 2004 | 01:03 AM
3rdGenSS's Avatar
Car: 91Z28, 94 Silverado, 99Z28
Engine: 350 TPI, 350 TBI, LS1
Transmission: 700R4, 4L60E, 6-speed
Axle/Gears: 3.42, 3.42, 3.42
i have a 115 mph cluster. i was going to use it in mine to replace the 85 mph but have decided to go with the 4th gen interior.. if interested or know someone that is just make an offer. later
Old Jan 23, 2004 | 09:39 AM
Bandit5's Avatar
If I ever get around to the 4th gen interior, I will have a very nice 90-92 145MPH cluster to sell.
Old Jan 23, 2004 | 07:08 PM
mckenzie's Avatar
i have a 91 z28 with a 350tpi. my tach didn't work either. i ran the wire from the coil to the cluster, (white wire) and found it broken at the tach diag. connector. it is a single gray connector in the engine compartment appx 6"-12" from the coil. it may not be a cluster problem, but just a wiring problem. best of luck, tom
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
fonzie85
Aug 13, 2015 11:50 AM
ChevyZ71
Aug 13, 2015 07:30 AM
