90-92 dash in a 89 iroc vert
Old Jan 26, 2004 | 06:03 PM
louiez70ta's Avatar
Car: 70 ta 70 camaro
Engine: 455 383
Transmission: 4 speed
i have a 89 iroc convertable i want to change my dash to the 90-92 dash how hard is it to do and what will i need to do this thanks a lot
Old Jan 26, 2004 | 08:13 PM
Bandit5's Avatar
The dash change will be very simple and straight forward, should bolt right on. However, the Speedometer cluster will not work. You are gonna have to do some rewiring to get it to work, especially since you are dealing with an electric speedomer since the '89 as not equipped with one.
Old Jan 26, 2004 | 10:35 PM
louiez70ta's Avatar
Engine: 455 383
what about the rest of the gauges rpm fuel volts temp all the check engine light brakes light etc will all this bolt right up and work
Old Jan 26, 2004 | 11:07 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
The dash doesnt just bolt right in, the metal mounts on the ends where the 4 10 MM bolts go for the 90-92 dash are very different, it wont fit right with the stock 82-89 mounts in there, you can drill out the spot welds and remove them, then leave it without the end mounts, or get a set from a 90-92 car and install them.
Old Jan 27, 2004 | 02:45 AM
gen3z's Avatar
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
use the entire 90-92 tpi dash harness and ecm,cant go wrong with the sweet dash,steering column&wheel,cool cluster and most of all speed density
Jorlain
Aug 24, 2022 05:11 PM
Gumby
Members Camaros
Aug 21, 2015 12:50 PM
Vintageracer
Aug 11, 2015 08:13 PM
mustangman65_79
Aug 11, 2015 03:17 PM
