Help, I bent my uni-body!!!
Old Feb 2, 2004 | 07:34 AM
MX265
Guest
Posts: n/a
Help, I bent my uni-body!!! Hey all, I got minorly rearended the other day while slowing down for a stop light....It was the shuttering sound of SCREEEEEEEEECCCHHH Wham!!
So be it..it happens...Didn't call insurenace, because they have it valued at $1050, even though $15,000 have gone in it...I didn't want them to total my car and take it away....
OK, long story short, The only thing wrong, is it appears as though he hit more of the right side of the rear bumper...Not much damage except for the Right Rear Seat is tilted to the left, and the latch engagement **** doesn't line up with the latch anymore... The latch on the seat is about an inch and a half to far to the left to line up with this ****....
So it looks as though maybe the rear subframe had been pushed in a hair and buckled outwards a hair towards the right fender....
Any thoughts on a fix for this????
Old Feb 2, 2004 | 08:22 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
if you kept your recepts, report it to insurance.
then fight for the car....
then they either fix it, (most likely) or they'll pay you your 15k.
its a long PITA process, but it probly will work out better.... if you kept track of everything.
Old Feb 2, 2004 | 12:53 PM
MX265
Guest
Posts: n/a
Hey MrDude... I apprecaite that input, but I have been over that conversation with the "what if's" with teh Insurance company, and it wasn't looking possible......
Does anyone have any technical ideas on this that may help?? I know alot of body shops use jigs with hydraulic jacks.... I just didn't know if someone had more specific info on this or other ideas.....
Old Feb 2, 2004 | 01:23 PM
85IrocNOH's Avatar
Car: 85 Iroc-Z
Axle/Gears: 10-bolt 3.42
pictures would be helpful
Old Feb 2, 2004 | 01:38 PM
MX265
Guest
Posts: n/a
OK, I can do that tonight... we'll post some pics.... Thanks...
Old Feb 2, 2004 | 02:57 PM
9T1 Z-28's Avatar
Car: 1991 Camaro Z28
Engine: 5.7L TPI
A body shop should be able to handle this. They would strap it down to frame puller and straighten the car out. This is a pretty standard task and shouldn't be too much trouble unless it is severly bent out of shape.
Old Feb 2, 2004 | 03:33 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
The insurance company isn't going to tell you it is possible to get what you have in the car out of it, but talk to a lawyer in your state and see if you have a case different states have different laws about this. However for the cost of the repair vs the increase in premiums will probably pay you just to do it out of pocket.
However if the unibody is bent then well you will need a good body shop to do the repair. They use a machine and mirrors to measure points on the car until it is exactly with in specs for the frame. You will never get that good of a result with a jig and hydralic jacks. Or buy a body and transfer eveything over, just make sure the body can be or has a clear clean title. Time wise body shop will be quicker, money wise a new body will be cheaper but will take alot of your time.
Old Feb 2, 2004 | 05:16 PM
fyrechikyn's Avatar
go and talk to the techs in a body shop, tons of us do side work and have acces to the shop keys, they might be able to pull it into specs for a couple hundred bucks on the side. but dont wait to long ins. wont pay if you wait to long to make a claim.
Old Feb 2, 2004 | 07:46 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
Go to a few body shops, jus like he said, we ghot keys for our shops, and stay late after work makin some extra money, few hundred should do it, depending on how bad it is...
Old Feb 3, 2004 | 07:14 AM
MX265
Guest
Posts: n/a
Cool!!!! Maybe I'll give that a shot...I didn't know about the frame pullers...Sounds better than a tie down and a tree.... J\K... That is exactly what I was looking for.......
Old Feb 3, 2004 | 01:55 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
The pontiac place in Gainesville(hall co) has one of the most advance machines in GA. Jim Hardman is the name of the place, but I doubt it will be cheap. Leasters in Gainesville is real good but they are one of the most expensive places here. I don't know of any small shops that have a real good frame machine.
Old Feb 3, 2004 | 06:06 PM
Charged350's Avatar
Car: 87 IROC Z28
Dont matter if they got top of the line 8 leg frame machine, when some dope is doing the pullin, a simple frame mashine with the right guy will take care of it, but remember ou get what you pay for...
Old Feb 5, 2004 | 03:02 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
The guy who hit you from behind did he have insurance??? Do you have recipts showing you put 15k into your car? If so i would go to an attorney and sue sadly enough that is the only way to fight with insurance companys.
dbrochard
Oct 3, 2015 12:43 PM
Zell1luk
Sep 29, 2015 10:36 AM
RedLeader289
Sep 23, 2015 06:50 AM
TOMcat GTA
Sep 15, 2015 09:31 AM
dbrochard
Sep 7, 2015 09:41 AM
