a cheap, good looking, non-stock body kit. look
Old Feb 4, 2004 | 11:45 PM
Dingley's Avatar
Car: 1986 Pontiac Trans Am
Engine: LG4 305
i found this on ebay... looks pretty cool. what do you guys think?
Attached Thumbnails a cheap, good looking, non-stock body kit.  look-82_93_ta_fbgroundeff1.jpg
Old Feb 4, 2004 | 11:46 PM
Dingley's Avatar
Engine: LG4 305
side view
Attached Thumbnails a cheap, good looking, non-stock body kit.  look-82_93ta_fbgroundeff4.jpg
Old Feb 5, 2004 | 12:04 AM
Agent13's Avatar
Car: 1983 Daytona Trans Am
Engine: LG4
Dont like it.... I think the stock ones look much better.
Old Feb 5, 2004 | 07:33 AM
Bandit5's Avatar
Makes it look more like a Camaro.
Old Feb 5, 2004 | 08:46 AM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
That body kit doesn't really match the lines of the firebird. It looks like a firebird that someone tried to make look like a Trans-AM.
Cheap and body kits usually produce one result when put together. Crappy body kits.
Old Feb 5, 2004 | 09:22 AM
hrddrv's Avatar
Car: 86 TA
Engine: 305 Carbed. Mainly stock Not running
Transmission: stock
I've actually seen it in person. It does not look too bad when you do a lot of custom work. But if you just leave it stock and add that it looks bad. A buddy of mine had it on his 87 and it took a lot of work to get it to match up right. After that and some other little things it started to look good but not great.
Old Feb 5, 2004 | 10:50 AM
Daishi's Avatar
Car: 1988 Camaro IROC
Axle/Gears: 3.27 9 bolt posi (non 1le)
If your putting that on ur car, just go buy a Camaro, put in ur FB interior, go out and take ur dremel to the GFX, and call it a day
Old Feb 8, 2004 | 01:25 AM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Year one supplys that kit. Its not really a body kit, but just a front air dam, gfxs, and a longer rear bumper.
Old Feb 8, 2004 | 05:05 AM
mastertrixter's Avatar
Car: 82 z-28
Engine: L69
Transmission: muncie T-10
hey trans am, i really hate to break this to u, but that is the exact deffinition of a "BODY" kit.
anyways, it basically makes it look like a camaro, like some fool bought a firebird thinking it was a camaro then decided instead of buying a camaro he'd just make his bird look like one.
Old Feb 8, 2004 | 04:03 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
I consider a body kit one that replaces the front bumpers, while here you just bolt the stuff on.
Old Feb 9, 2004 | 03:04 AM
neubauej's Avatar
Car: 89 Formula
Engine: LB9
Transmission: WC T-5
I'm not too fond of it, but I like the clean look of a formula, that looks like a formula with out-of-place add-ons. Just my opinion
Old Feb 9, 2004 | 07:34 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
see! so it DOES make it look better!
:lala:
Old Feb 9, 2004 | 09:18 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
:lala:
Yuk, Only a camaro owner would blaspheme like that.
Though its does have a camaro TA look but a TA is a just a Firebird.
Its GM's fault but the Firebird is the main competitor for the Camaro, because they said " leave the poor Vette alone" Firebird was to be a Vette killer.
They had a good show on TV about the Pontiac division and how really different they are or were. Firebirds might as well been a Ford.
Its Firebird /TA against Camaro \Irco.
Whole reason Pontiac dropped the TTA cause it used a Buick motor, they did tweak it some but could not stand having Buick parts in it? But will let Chevy force engines on them? The 3.8 was a better motor.
There is no love in the GM brands. Pick your side and stand your ground.
Buick, Pontiac, Olds, then Chevy for me.
italiano67
Dec 11, 2016 09:21 AM
dutch930
Sep 11, 2015 06:58 AM
justin57
Aug 20, 2015 07:05 PM
ezobens
Aug 19, 2015 10:29 PM
mustangman65_79
Aug 7, 2015 09:55 PM
