how is water getting in?
Old Feb 7, 2004 | 01:32 AM
icebird_1981's Avatar
i was helping my friend work on his 84 trans am and we noticed both driver and passanger floor has water under the carpet and u can see a stain were it is comming from. i made a quick drawing so u no just what i mean but both passanger and driverside had the same stain trail in the same spot.. i am thinking is has something to do with those vents were the wipers are?? and i am guessing those vent are there to get rid of water right??? and somehow leaking into car. how do we fix this problem its just killing the carpets and cant be good for the floor boards.
Old Feb 7, 2004 | 02:05 AM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Passenger side could be from the fender hole (don't know the technical term). Your wiring harness goes through it to plug into the ecm, it may be lose, only hole I can think of that would put water in from the rocker panel on the passenger side, drivers side im not too sure.
Old Feb 7, 2004 | 03:06 AM
Agent13's Avatar
Car: 1983 Daytona Trans Am
Engine: LG4
Could it be the heater core?
Old Feb 7, 2004 | 11:25 AM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
Well heater core is usually antifreeze and youll deff. know if its that. But Im sure water could get in through a hole in the fender or maybe the door?
Nate
Old Feb 7, 2004 | 03:08 PM
jlarsson's Avatar
Car: 1989 TTA
Engine: 3.8L Turbo V6 - VIN 7
Transmission: 200R4
Had the same on my 84, it's the firewall. Up where you have the drainage just below the windshield wipers you have a cover "net" (not sure about the proper English term as I'm Swedish :-) if you remove this you will see there is some different sheetmetal meeting and seems like the water came in that way. I use a spray can of clear undercoating and filled that area and it stopped the leakage over the years it came back so I had to re do it.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
sheachopper
Jul 31, 2019 11:27 AM
jrdturbo
Mar 31, 2016 02:58 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
st.evel07
Sep 19, 2015 09:24 PM
