Seat belt and fuel system safety recall on a 1989 firebird
Old Feb 13, 2004 | 10:14 AM
joshwilson3's Avatar
Old Feb 13, 2004 | 11:16 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
The Seatbelt was for all. If you car has had the seatbelt recall then you can tell, unless you happened to be one of the ones they replaced the whole buckle for. If you look at the red (probablly pink now) button there will be a little tap on the edge if its been replaced.
The Fuel system was For specific engines/vin numbers. I beleive it was either V6's or the TPI V8's but not sure which specific engines it was for in 89.
Old Feb 13, 2004 | 07:04 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Looked on the NHTSA web site, the fuel deal was a hose under the hood on V6 engines, the belt was a plastic piece in the buckle that the sun damages.
Old Feb 14, 2004 | 01:01 AM
Old Feb 14, 2004 | 11:34 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
This is a pdf of the recall. This is all from the NHTSA but its burried in there site so I just put it on a server I have access to.
Seat Belt recal
This is the NHTSA site about it.
http://www-odi.nhtsa.dot.gov/cars/pr...ls/results.cfm
You can also call the NHTSA and findout if they have any more information about you car.
1-888-327-4236
For those with the V6, and are worried about the gas leak.
gas leak
Old Feb 14, 2004 | 11:41 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
1989 Van Nuys from KL200001 to KL264406,
but the dealer is required to replace all if one is showing signs of becoming brittle or has broken. If the button has turned pink then you will have to push the issue.
Old Feb 14, 2004 | 04:53 PM
1992 Trans Am
May 10, 2023 07:19 PM
midge54
Dec 27, 2019 04:14 PM
colton_carlson
Mar 8, 2019 12:21 PM
kyleb24
Aug 15, 2015 08:24 AM
scottmoyer
Interior Parts Wanted
Aug 9, 2015 10:18 PM
