really REALLY dumb question...
Old Feb 13, 2004 | 05:38 PM
StreetRoc85 350's Avatar
Car: 88 IROC
Transmission: Pro 5.0 shifted T56
Axle/Gears: 10 bolt 3.73 posi
Ok, this is probably the stupidest question ever to grace the boards but... :lala:
Where is the bright/dim switch on the firebirds? Ive had my 'bird for almost a year now and I cant find it for the life of me. I know it has to be somewhere, there are 4 wires coming out of my headlights, not 2.
I know this sounds really dumb, so Ill just bite the bullet and take all the flames this is bound to bring....
(moderators please have mercy and delete this as soon as i get an answer, thanks!)
Old Feb 13, 2004 | 05:48 PM
X86TRANSAMWS6X's Avatar
Car: 87 Conquest TSI, 86 Fiero GT
rite above the headlight switch
Old Feb 13, 2004 | 06:31 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
The bright/dim switch for the headlights is part of the turn signal switch. Pull it toward the steering wheel and it will click and then release. Ths dimer switch aboave the headlight switch only does the inside lights.
Old Feb 13, 2004 | 10:44 PM
OHH.. you sould've said high beams buddy
Old Feb 14, 2004 | 08:28 PM
Car: 88 IROC
Ok thats what i was afraid of. My turn signal switch pulls back but wont click or work the brights. Time to pull the steering column and change the switch
Old Feb 15, 2004 | 08:34 AM
Morley's Avatar
You don't pull the column, just take the nuts off the bottom that hold it up (need to drop the under dash panels). The dimmer switch is mounted on top of the column towards the left along with the ignition switch. Just loosen the 2 screws holding the dimmer and slide it towards the steering wheel and retighten the screws. See if the switch works now, if not you'll need to replace it.
Old Feb 15, 2004 | 05:54 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
yeah its not really hard at all
Galaxie500XL
Oct 1, 2015 01:05 PM
Rally Smith
Sep 14, 2015 06:59 PM
NinjaNife
Aug 23, 2015 11:49 AM
happyhapka
Aug 15, 2015 04:42 PM
White_Boii
Aug 27, 2001 09:31 PM
