aftermarket high rise spoiler install
Old Feb 14, 2004 | 01:34 PM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
Transmission: T-56 LT1
hey guys, just got a high rise spoiler for my 91 camaro off ebay, I just set it on the camaro last night, and the two inner pillars done even hit the hatch surface, the two side ones come in contact first. does anyone have or could take some pictures of theire spoiler so I can line it up correctly. and maybe this spoiler is how correct, and the hatches that DID have the high rise, had two small raised platforms that contoured to the spoiler? but I'll takes some pix and we can see what I should do, what could I use? without looking at it again I'd say I have 3/4's of an inch of play? piece of wood to go under it? give me some ideas
cheers
Blake
Old Feb 14, 2004 | 02:29 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: aftermarket high rise spoiler install
There is only one style decklid made for all years/makes of these cars. Spoiler holes were the only difference. The wing you have sounds like it's just warped.
Here is the one that was on my 'bird... it was an A&A wing but, it's probably 99% accurately made as compared to an OEM one... the wing should sit perfectly flat all the way across..
Old Feb 14, 2004 | 04:24 PM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
you can see that gap thats left there, its about a half inch, should I maybe sand down the side pillars that are hitting the car and then fibeglass the bottom of them, I work with fiberglass a little bit and my dad works at a fiberglass drag boat place so I coudl get a really good job done.
cheers
Blake
Old Feb 14, 2004 | 05:46 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
looks a lot how mine did when i got it...when i tightend mine down most of that gap goes away...probably not the best thing to do though as its puttin a lot of pressure on it. is going to give me a few problems as well im sure, did you get that off ebay as well
Old Feb 14, 2004 | 05:55 PM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
yes I did, maybe we should think about making a rubber spacer made of truck bed lining? or just adding some fiberglass wouldnt hurt, depending how comfortable you are with it
cheers
Blake
Old Feb 16, 2004 | 10:42 AM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Re: Re: aftermarket high rise spoiler install
That pic is really wierd. Either your car has a wide body kit..... or, that wing is too short. eek. Or is the bird wider in rear?
Old Feb 16, 2004 | 11:54 AM
Pillsbry10's Avatar
the birds are a tad wider but that wing is also to short for the camaro...as i have one of those as well
Old Feb 16, 2004 | 11:55 AM
5SIZ's Avatar
Car: 1987 IROC-Z
i was about to buy the ebay online one, good thing i read this first.
Old Feb 16, 2004 | 11:59 AM
Pillsbry10's Avatar
its not a horrible spoiler really just not great, but for the money cant complain to much, if your handy you can make it work just fine
Old Feb 16, 2004 | 03:58 PM
deadbird's Avatar
Engine: TPI 305/ v6
Pills is right. Birds are roughly 1" wider on each side as compared to camaro's. Mine was not the same as either of you have however. It fit just as OEM on a camaro because it was actually made with some craftsmanship :P (j/k). The A&A wings were near duplicates of OEM wings and quite superb in quality. My A&A wing seemed just as heavy if not, slightly heavier then the 4thgen I now have.
As far as your problem, Blake (and Pills too), I would trace the center pillar bottom onto a piece of plywood (of the near correct size for the gap) and undercut it slightly, drill a larger hole than you need for the bolt, and glass it to the wing. Then you need x" longer bolts for the wing.
That's just my opinion though...
Old Feb 16, 2004 | 04:11 PM
Pillsbry10's Avatar
yeah ill probalby do something about that after i get through all the other crap i gotta do...woo hoo one more thing on my list, ya know how it is =)
Old Feb 18, 2004 | 03:25 PM
Matt_91RSTPI's Avatar
My high rise spoiler from Wings West included two black plastic gaskets to go under those pillars. The outside edges do not come in contact with the rear quarters of my Camaro.
Old Feb 18, 2004 | 03:47 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Ahh that must be the wonderful one that spoiler2000.com sells, what a pos it was and a fight to get them to take it back, tried to warn people about them.... stay AWAY, the wings west one is pretty nice, too bad A&A went under or stopped making them, that one even fit the stock 91-92 Z28 decklid for the mounting holes.
Old Feb 20, 2004 | 06:55 AM
LUVmy92's Avatar
Car: Camaro
Mine did the same thing, I paniced as well, then I pushed down on the damn thing and it fit and looked fine! Its just how it goes with those spoilers. I got mine the same place you did too! Heres a pic after the install........
It came out just fine with no problems other then my painter not taking enough time to prep it for paint and now it has some bad spots in the paint. Its just what you gotta deal with if you go cheap ($189) and not GM ($499)!
Old Feb 20, 2004 | 02:03 PM
91Zman's Avatar
Car: 1991 Z28
Transmission: 4L60 automatic
The ends look like they are a tad taller than my stock wing
Old Feb 20, 2004 | 02:55 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
This is the factory wing on my 91 Z-28:
The aftermarket ones aren't as wide.
Old Feb 20, 2004 | 04:27 PM
LUVmy92's Avatar
Car: Camaro
WOW now I feel cheated! Yours is an inch or three bigger! I wonder if theirs a pill to make my spoiler grow a couple inches like they advertise for a guys di....... uh never mind.
Old Feb 20, 2004 | 04:37 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Of course mine's bigger! no pills needed here.
Old Feb 20, 2004 | 04:47 PM
LUVmy92's Avatar
Car: Camaro
Now I need counseling... thanks alot 1bad91z!
Old Feb 20, 2004 | 04:55 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
No prob!
LilHot
South Central
Apr 13, 2026 11:46 PM
Frozer!!!
Jan 19, 2024 04:55 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
Fronzizzle
Aug 17, 2015 02:52 PM
