wheel adaptor question...
Old Feb 15, 2004 | 03:27 PM
lilthurmy03's Avatar
Car: 85 Camaro Z-28
you guys w/ 4th gen. wheels on youre cars, what size wheel apadtors do i need? will a 1 1/4 inch adaptor work? or do i need 1.5 or a 2 inch adaptor? found a good deal on four 1 1/4, will they work or will that not be thick enough? thanks.
Old Feb 15, 2004 | 03:41 PM
Kandied91z's Avatar
sometimes it just takes a little searching....
http://www.skulte.com/adapterfaq.html
i have a front pair of eibach pro-kit springs barely used for $75 and i'll split shipping if your interested. i'll have the rear set up for sale shortly too once the rear suspension is finished next month.
Old Feb 15, 2004 | 07:23 PM
Car: 85 Camaro Z-28
yeah ive read that... it recommends the 2 inch spacers, but what im trying to figure out is, is it a must? because if the 1 1/4 adaptors will work, then im going to buy them. i just found a set (all 4) of hotchkis springs for it, but if it falls through, ill let you know.
Old Feb 15, 2004 | 07:45 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
1 1/4 won't cut it for the front. You'll need a minimum of 2" I believe.
Old Feb 15, 2004 | 10:02 PM
Car: 85 Camaro Z-28
ok thanks karps. can i get additional spacing, say just reg. 1/2 wheel spacers, and put them in between the adaptors and the axle lugs? or do you not think that would work? its just these a good deal, and im trying to figure out a way to make them work.
Old Feb 15, 2004 | 11:43 PM
Kandied91z's Avatar
yes it definately won't cut it. you could possibly go a hair shorter to have the wheels further in where they should be but then your looking into custom grinding and it isn't cheap.
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
drptop70ss
Oct 4, 2015 09:44 PM
Saxondale
Sep 15, 2015 06:42 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
