door hinge problem
Old Feb 21, 2004 | 08:50 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
door hinge problem
Ok this is kinda odd. I got rearended about a month ago, the car was towed back to my house 2 weeks ago. Now when I went to shut the driverside door after we got it on the trailer it was fine. My parents towed it home, I stayed at school. When I got home the next week the door was sagging. Its got enough play in it to where I can lift it up. It goes up about 1/8-1/4 a inch( not a lot, but noticble) It wont close at all, it hits the gfx. What happened? How can I fix this? The door was perfectly fine after the accident and right before it was towed out. Now all of a sudden it sags. The other door is fine, just sags a little, which is the same as it was since I got the car.
How much is a hinge repair kit, I dont have much money to spend.
Thanks,
Matt
Old Feb 22, 2004 | 12:14 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I sell two hinge repair kits from 3rdGenSolutions (aka Andy Z28). The Standard non-greasable kit is $74. The Greasable upper door hinge repair kit is $96. Both kits repair one door. If you don't have one you should also buy the GM Door Spring tool which helps you safely remove and re-install the door spring in the lower hinge.
Lon Salgren
Top-Down Solutions
1992 Trans Am
May 10, 2023 07:19 PM
1Aauto
Sponsored Vendors
Apr 9, 2018 03:00 PM
86IROC112
Apr 9, 2016 10:20 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
