broken stud (need help please)!!!!!!!!!
Old Feb 23, 2004 | 09:32 PM
jcurrieirocz's Avatar
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
seems i broke a stud/bolt off my car how can i get it off out???? The bolt/stud is what holds my break caliper to my car....any ideas has anyone done this before also.....
i had put penetrating fluid on them and when i was taking it off it snaped the hex head right off it clean....sence the treads are about an inch long and they are holding my brakes on i dont wanna reck the threads drilling it out cause its so deep.
anyhow has anyone broken this same stud/guide too what did you do???
thanks
Old Feb 23, 2004 | 09:46 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
If you are talking about the caliper bolt that threads into the spindle, you could try getting some vise grips on the other end of it (the smooth end that the caliper slides on) and seeing if you could loosen it.. That combined with some PB Blaster or other equivalent thread penetrant might do the trick..
Old Feb 25, 2004 | 05:32 PM
Car: '81 Trans Am
Engine: 6.6L
yah not sure if i can get enoght room to get a pair of vg's on there good enoght.....plus i thing if a ratchet with a pipe on the end will break it of a pair of vg's maybe useless...
mmmm
any more ideas
sheachopper
Jul 31, 2019 11:27 AM
apie2546
Oct 16, 2016 02:24 PM
no green
Jan 9, 2016 09:22 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Reid Fleming
Oct 10, 2015 09:56 PM
