Cargo Hatch Problems??
Old Feb 27, 2004 | 02:50 PM
knight75's Avatar
Car: 1987 Pontiac T/A with Knight Rider conversion
Engine: 2.8 V6
Transmission: 700r4?
Hey guys I'am having problems with my hatch not catching but the hatch motor is going down fine. Its just not catching the hatch? Anyone else had this trouble? Any Ideas?
Thanks for your time!!
knight75
Old Feb 27, 2004 | 03:38 PM
HeavyBreathinRS's Avatar
Car: 1990 RS
If you closed the hatch very lightly making the electrical contact, then slightly lifted the hatch quickly, you may have triggered the capture mechanism.
Have you tried using the key to reopen the clasp?
Other than that, check:
Rubber bumper stops are not up too high.
Hatch pull down motor assy might be loose from the body, and have slipped too low to let the capture happen.
Alignment of the steel hook capture loop on the deck lid.
Old Feb 27, 2004 | 04:41 PM
knight75's Avatar
Engine: 2.8 V6
Hey thanks for the reply HeavyBreathinRS. I tried the key and that didn't work. I also used a screwdriver to close the hooks that catch the hatch and they wont lock into closed position. And my hatch pop sylenoid isn't working either. It don't do that loud pop like it used too.
Knight75
Old Feb 27, 2004 | 07:09 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
sounds like you lost your power to it. check your fuses or use a test light one the connector to see if it has juice when you hit the pop button. motor may have bought the farm as well, but i would look at power first.
Jeff
Old Feb 27, 2004 | 07:42 PM
knight75's Avatar
Engine: 2.8 V6
I took the ground wire loose and touched it against the car body and I got sparks. I think maybe the sylenoid is shot. It wont make a sound.
Knight75
Old Feb 29, 2004 | 12:26 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
See High Perf Pontiac Oct 2002
There is a story on exactly that problem and how to fix it in High Performance Pontiac Oct 2002. It sounds like your plastic motor mounting boss has broken, and the whole assembly sags. The story shows how you can fix it with a little glue and a hose clamp.
High Perf Pontiac back issues
(866) 601-5199
Good luck
Troy
So Cal
Street Lethal
Apr 30, 2019 12:14 PM
I'llrocya
Feb 2, 2016 11:43 PM
hydrolic144
Sep 8, 2015 06:55 PM
neekolzun
Aug 24, 2015 04:59 PM
madsv1000
Aug 20, 2015 06:45 AM
