climate controls
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
climate controls
i have a problem with my HVAC controls. it will only blow out of the defrost vents. i read the tech article but it wasn't any help. it makes a hissing noise when anything other than off is selected. i need pictures of where things are and what they look like. thanks.
Umm . . . Most all cars make that hissing sound when you select a different setting. Altough im not 100% sure but if the controls are vacuum operated (like some cars) then you may have a vacuum leak.
If they aren't t hen your blend/mix door may be stuck. And to fix that requires puuling down the passanger side under part of the dash and looking around.
Hope this helps,
Sean
Hope this helps,
Sean
Hope this helps,
Sean
Hope this helps,
Sean
can anybody get me a few pics of what thsi stuff looks like and where it can be found?
