Door Hinge Repair
Old Feb 29, 2004 | 10:40 AM
87Formula356's Avatar
Car: 87 Formula Firebird
Engine: 5.8Ltr 356
Transmission: WC t-5...... probobly go boom soon.
Door Hinge Repair
I want to replace my door hinges so my door don't sag, the problem is that i went to the top down solutions website and it seems like it's a much more expensive problem than i thought. i read in high performance ponitac that all you need is new bushings, and mabye the 2 bolts, it seems like the TDS kit has alot of extra parts that i don't want to pay for.
Anyone fix this problem cheaply?
Old Feb 29, 2004 | 11:49 AM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
...Depends on the problem
Hi Formula:
I wrote the story in HPP. The crux of the issue is if your top hinge is bad, it is a rivetted design, and is a true bastard.
The top hinge is about twice the diameter of the bottom hinge, and is not designed to be serviced. The bottom hinge takes most of the abuse, and has the spring detent built into it, which just makes them wear more quickly. Follow the instructions and see if the top hinge is worn. Mine were fine.
Any dealer or even Autozone, Pep boys, etc has the bottom bushings and pins in the "help" section. It shouldn't cost more than about $15.
let me know if you have problems
Troy
So Cal
Old Feb 29, 2004 | 02:13 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
saw someone selling a top set on ebay for 30, it wasn't the same as tds's, I was thinking about it but I want to see someone with it before I buy it. Has anyone used this kit?
ebay listing
Old Feb 29, 2004 | 04:11 PM
Engine: 5.8Ltr 356
thanks guys, TA, any idea which issue it was that the door hinge article was in HPP. i have tons lying around and i don't know which to pick up.
Old Mar 1, 2004 | 05:06 PM
irocdan's Avatar
Car: 88 Iroc vert
Engine: 305 tpi. cts-v brakes
Transmission: Tremec T-56
have you emailed lon at tds?ask him,hes a real nice guy
Hotrodboba400
Dec 10, 2019 07:07 PM
chuck13
Interior Parts Wanted
Sep 22, 2015 11:19 AM
84 TA NV
Sep 6, 2015 08:02 PM
mrdevontay
Sep 2, 2015 08:04 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
