Headliner Questions
Old Mar 5, 2004 | 05:07 AM
vhenem's Avatar
Car: 1984 Berlinetta
Engine: LG4
Headliner Questions
I have the typical 20 year old headliner problem, sagging, torn material etc.
I was going to recover it but the liner backing is disinegrating, I then decided to just fibreglass over it but I am afraid that the resin will just melt the foam.
Any suggestions as to what I can apply over the backing before I glass it so that this doesn't happen ?
Old Mar 5, 2004 | 07:44 AM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
interesting idea, never thought of fiberglassing it...any type of plastic covering the backing pad should work fine...even duct tape or something should keep the resin from eating at the foam long enough for it to set up...once the fiberglass has started to set up, the backing probably won't matter much.
be sure to post some pics when you get it done
Old Mar 5, 2004 | 10:48 PM
vhenem's Avatar
Engine: LG4
Ahh yes the incredible substance known as duct tape:hail: , I had thought of that but was hoping someone knew of a spray on or brush on varnish/shellac type finish for foam, if that is even what that yellow, crumbling stuff is under the cloth.
I intend to make a mold first and then if that turns out ok making up the headliner minus console/dome light holes.
Frozer!!!
Jan 19, 2024 04:55 PM
Victor6
Aug 30, 2015 02:09 AM
Golfvette
Aug 24, 2015 06:35 PM
redmaroz
Aug 16, 2015 11:40 PM
TheJoeY88
Aug 13, 2015 06:51 PM
