Doors not opening help!
Old Mar 23, 2004 | 06:46 AM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
Hey guys!. Im having a problem with my door. My stupid brother got his coat stuck in the door and yanked it out. After he did it the door wouldnt open. On the inside you can see the lower plastic panel about 1/2 inch maybe Like it wasnt closed all the way. I tried looking for something out of place inside but couldnt figure it out without the panel off. My question is what could it be and how hard would it be to take the panel etc. off. Is it a hex screw under the arm rest? What else do I need to take off to get it off? Im gonna wait until friday to do it but Id like to know how hard its gonna be and how I should go about figuring it out and what to look for. Maybe a description?
Nate
Old Mar 23, 2004 | 09:46 AM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
take the screws out of the arm rest then there are two (if i remember right) screws behind the plastci pop off panel by the top of the door handle.Then their is clips holding the panel on the door that you'll probably destroy prying the panle off. You'll probably need new ones.
Old Mar 23, 2004 | 09:01 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Doors not opening help!
Nate
I f you cant open the door.You wont be able to remove the door panel.
Old Mar 23, 2004 | 09:10 PM
br()bert's Avatar
Car: 85 firebird
yes you can, its harder but you can do it.
Old Mar 23, 2004 | 11:10 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
he should be able to just barely get it off
its gonna be a PITA though
Old Mar 24, 2004 | 05:58 AM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
well I need to take off the panel to get to the piece that opens the door right???
Nate
Old Mar 31, 2004 | 08:03 AM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
any suggestions? is the star bolt the same size on the bottom as it is on the top? Im gonna need a few tools....
my86bird
Oct 23, 2015 12:20 PM
billybob6110
Sep 23, 2015 01:30 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
