Needles not Moving after new gauges
Old Mar 23, 2004 | 12:43 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
i recently purchased some sweet overlays for my 91 z and got them on however my battery and temp seem to be the only gauges working. i didnt pull the needles up at all but i was wondering if there was another way to break them to where they wont turn or are they just stuck on the overlays???? anyone else ever ran into this problem?
Old Mar 23, 2004 | 01:49 PM
91zconvt's Avatar
Car: 87 Iroc
Try pushing on the gauge cluster. Sounds like the plugs just aren't making full contact with the cluster
Old Mar 23, 2004 | 02:21 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
ill go mess with that a little bit more then. i tried that and it seems like it made a couple move but not much. i guess ill go at it again.......any other suggestions?
Old Mar 25, 2004 | 02:29 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
TTT
cmon guys i seriously need help here. i konw someone has the answer. is there a way to break the needles even though i didnt pull them up or are my overlays just getting in the way????
Old Mar 25, 2004 | 07:18 PM
91zconvt's Avatar
Car: 87 Iroc
unless you can actually see them physically stuck on the overlays, I can't imagine that being a problem. Especially seeing it's every gauge. If they were stuck, I think they'd twitch at least a little because they're trying to move. The only thing I can think of, is hat the gauges aren't making full contact with the harnesses.
did you touch any of the wiring? If you moved the plugs, make sure you put them back in the right spot, and they're not reversed
Old Mar 25, 2004 | 09:53 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
i have the same problem. mine stick. i have to flick the gauge cluster to get them to move. it does that mostly with the oil pressure and the battery gauge. my fuel gauge died after i put the overlays in. i replaced the gauge, and now it works, but not accurately. it starts full and ends empty, but between there is a total mess, lol. im thinking next is the sending unit/pump. but not for a while.
Old Mar 25, 2004 | 09:57 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
well while i turn my key to the ON position the needles that work will move like they are supposed to but when if let the key go they fall back down and seem to stick on the gauge overlays. however the other gauges (speedo, tach, fuel maybe) dont move at all. im gonns try to move the overlay wires around to see if i am not making full contact and then il will try to remove the overlays and see if they were the problem. if not im up a creek........
Bubbajones_ya
Jul 6, 2024 08:32 PM
nova983
European Region
Nov 2, 2015 12:15 PM
TrevinE
Sep 14, 2015 03:20 PM
86IROC112
Sep 11, 2015 04:04 PM
Glowsock
Sep 6, 2015 06:40 AM
