dash lights wont work
Old Mar 23, 2004 | 11:24 PM
86birdy's Avatar
Car: 89 Firebird Formula
Engine: 400+ hp 350
Transmission: turbo 350
Ive got 2 birds, a 86 v6 bird and a 89 formula and i cant get the dash lights to work on either one of them. Ive checked all of the fuses and wireing but i cant seem to find out what is worng. Is there a relay somwhere that could have went bad? Any thoughts/ opnions appreciated, thanks
Old Mar 23, 2004 | 11:32 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
quick tip
take the headlight button and mess around with the brightness might help. dunno how to do in a bird but i can do it in my camaro
Old Mar 23, 2004 | 11:54 PM
86birdy's Avatar
Engine: 400+ hp 350
Well ive messed arround with the turn signal switch because the turn signals dont work either, everything seems pretty solid and looks as if it is working but the steering column is really loose, u can move it a good 4 inches in each direction. My dad said its just a bad worm gear and it can be fixed, do you think i need to just replace the column? thanks
Old Mar 24, 2004 | 12:08 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
should be the coloum just loose wires imo
Old Mar 24, 2004 | 12:11 AM
86birdy's Avatar
Engine: 400+ hp 350
ya makes sence right? but the column in the 86 is normal, no movement what so ever, ill check them anyway. thanks
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
marcusaw
Aug 10, 2015 08:13 AM
apie2546
Aug 8, 2015 07:12 AM
