Help my Dashpad!!!!!
Old Mar 26, 2004 | 01:17 PM
Daishi's Avatar
Car: 1988 Camaro IROC
Axle/Gears: 3.27 9 bolt posi (non 1le)
My dashpad is 100% perfect, its the orig one from factory. No fading, no cracking. How can I keep it this way?? Everyones is cracking into nothingness... I dont wanna cover it, cause its perfect. Is there something i can rub on it?
Old Mar 26, 2004 | 05:28 PM
white91formula's Avatar
Car: 91 formula
Transmission: t5
mcquires leather and vinal cleaner/conditioner
DO NOT use armorall, something in it drys up the dashes and helpls the cracking process
also if you live in a climate with cold winters take it out durning the winter so that the freezing temps do not get to it. mine is in my closet still and will probably be there untill mid to late april
hope this helps :lala:
Old Mar 26, 2004 | 06:57 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
heat kills them and anything that produces a shine when rubbed on will dry it out. same goes for your tires people, that tire shine is killing your treads
Frozer!!!
Jan 19, 2024 04:55 PM
Linson
Nov 12, 2015 08:09 PM
jerflash
Sep 23, 2015 09:21 AM
DoBeR
Sep 2, 2002 06:38 PM
