help removing rears seats
Old Mar 29, 2004 | 07:45 PM
89rsalberta's Avatar
Car: 89 camaro rs
Engine: 305 tbi
Transmission: 5 spd
I want to remove the rear seats to make room for stereo and acc
Old Mar 29, 2004 | 08:17 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
Its simple bro. 2 nuts hold the back pieces on and 1 bolt holds the bottom piece on. I think they are 10mm.
Mike
Old Mar 29, 2004 | 08:19 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Are you asking how to take the seats out? As in... you don't know where the bolts are? I pretty sure the bolts for the bottom parts are directly under them and the tops have a bolt on the side(closest to outside of car). Just look, you'll see it.
Old Mar 29, 2004 | 08:50 PM
83Firebird420's Avatar
Car: 87 GTA 120,000k, 90 CRX Si
Engine: 5.7 TPI, 1.6L 16 valve SOHC
Transmission: 700r4, 5spd std
yes its very easy..the 2 holding the bottom part of the seat down and then u should be able to see exactly what bolts to take the top part off
Old Mar 29, 2004 | 09:40 PM
Formula4Speed's Avatar
Car: 1990 Formula
Engine: 305 TBI (LO3)
Transmission: 5 speed manual
On the bottom part in the front dead center under the bucket there is one 13mm bolt for each, take that off and on the sides you will see 2 more facing downward also 13mm. The seat belt guides are the hard part they have torx bolts with loc-tite on them so make sure you have a torx set for your ratchet.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
MORREALE5
Sep 13, 2015 09:16 PM
3rdgenparts
Aug 8, 2015 07:09 PM
z28addict8490
Aug 7, 2015 08:48 PM
