Help please/elec.door lock slider
Old Mar 31, 2004 | 12:44 AM
dennisgramm's Avatar
Car: 1983 Camaro Z28
Engine: 5.0L HO
Transmission: 5speed
Hi, My 83 z28 doors have electric door locks, both solenoids work fine on opening door when locked, but when in unlocked position and you push switch, my passenger side door slider will only go part way, unless you keep hitting switch 4-6 times. Of course you can manually lock it fine. I just had new weather stripping put on today at a body shop, and when they put the doors back together, the slider did the same thing. Is it just binding somewhere, or need some white grease/wd40? Appreciate any ideas,
thanks, Dennis
Old Mar 31, 2004 | 07:38 AM
Screamin'87GTA's Avatar
Car: Trans Am GTA
Transmission: Rebuilt 700r4 with stage 3
I think that is a very common problem... Mine does exactly the same thing.. I am going to put in aftermarket actuators for the locks.. there is a little "elbow" in the door that can be greased but if it locks ok i wouldnt think that was it..
jrdturbo
Mar 31, 2016 02:58 PM
kkirch15
Sep 30, 2015 04:44 PM
timonator
Sep 30, 2015 12:52 PM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
