doing the shaker hood mod
Old Apr 9, 2004 | 12:11 PM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
I've done some searching on the board, and found lots of info on the shaker hood on a 3rd gen. Here's what i have so far:
3rd gen T/A's have a low intake to hood clearance
I need to get the scoop from a 77-81 T/A, and make it functional
this scoop WILL clamp on to my stock air cleaner housing
that's what I gathered. what i need to know is these:
the T/A hood slopes down, the old ones were flat. do i need to tilt the shaker, or install it flat to duplicate the right effect?
I'm running a performer RPM intake. will the shaker set-up work with my car?
any other tid bits of info would be great. I'm bidding on scoops on ebay, and I kinda need to know soon if this isn't feasible with my intake. I know some of you guys have done this. is it worth the hassle? it looks awesome, and provides a great alternative to the minimal hood choices we have for our cars. thanks in advance for the help, guys.
Old Apr 9, 2004 | 02:35 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: doing the shaker hood mod
IMO, the 3rdgen Firebird hoods are level enough near the back (where the carb is) that it would look right. I'd just install it 'flat' on the carb.
The intake manifold won't make any difference, except maybe how high it will sit. The shaker sits on your carb, not your intake manifold.
Old Apr 9, 2004 | 04:00 PM
Car: 1982 Trans Am
Engine: 383 chevy
that's what I'm worried about. I'm afriad there may not be enough clearance to allow the shaker to sit.... which will mean I'm stuck with a scoop i can't use. any other info?
Old Apr 9, 2004 | 05:44 PM
Air_Adam's Avatar
what do you mean 'not enough clearance'? Its basically just an air cleaner lid, isn't it?
Old Apr 9, 2004 | 05:57 PM
MNformula350's Avatar
I could be wrong but i thik you would need the lower air cleaner assembly too, it's been awhile since i worked on or saw a second gen T/A but i thik the whole air cleaner assemblly is shaped almost like a turbo 350 tranny pan
Old Apr 9, 2004 | 06:01 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
clearance should not be a problem. lots of room.
Old Apr 9, 2004 | 09:21 PM
Car: 1982 Trans Am
Engine: 383 chevy
ok. one last check before i bid: I should get the 77-81 shaker, and lower air cleaner assembly, and remove my 1" carb spacer..... and the whole shaker assembly will fit on my carb, on top of my performer RPM intake?
Old Apr 9, 2004 | 10:20 PM
87and 93birds's Avatar
Car: 87bird and 93 formula
Engine: 305 and 350
Transmission: auto
i am in the process of doing this myself and the shaker won't fit on my air cleaner so i got a whole ***. off of a 79 with the cleaner too. it does need a spacer to clear the thermostat switch and to bring it up to the hood.
Old Apr 11, 2004 | 12:38 AM
Car: 1982 Trans Am
Engine: 383 chevy
but you're running the stock intake, right? I'm running a performer RPM.... it's a couple (3-4) inches taller than thre stock piece. the air cleaner clears the water neck just fine. my problem (maybe it isn't one) is that right now, on my car, i have the RPM intake. I put on a 1" carb spacer, and the carb barely clears the hood... the front of the carb is about 1/2" to 1" from the bottom of the hood.... if you remove the bracing first. what I need to know is, if I remove the spacer, cut the bracing out, will i have enough room to mount the entire shaker assembly. is there any way to find out? some one has got to have tried this on a car set up like mine.
Old Apr 11, 2004 | 02:41 PM
Engine: 305 and 350
Transmission: auto
[QUOTE]Originally posted by flyitlikustolit
i am using the stock intake and it looks like i will need about a three inch spacer to bring it up to the hood with the pontiac air cleaner from a 79 so if you remove the carb spacer and have the pontiac air cleaner if should bolt right up.
Old Apr 11, 2004 | 04:40 PM
Car: 1982 Trans Am
Engine: 383 chevy
bad @$$. I think this will work after all. I just bought one with an air cleaner and everything. how tall is your intakefrom the china wall to the carb flange? I'm going to measure mine tonight, and then the difference will help tell me what i have to cut off of the air cleaner.
Old Jul 7, 2004 | 02:25 PM
Poncho Villa's Avatar
Car: Badass 1991 Firebird
Engine: Screamin' 305 TBI
Axle/Gears: 2.73, 3.42's waiting to go in!
Reverse The Shaker?
I got the Shaker bug too! Just bought a 70-76 Trans Am shaker, because it has the largest opening. Didn't really think about clearance differences, but I'm sure I'll figure it out. I just got the scoop, a functional open one, so I'll have to fab the lower assembly myself, or get it from the local junkyard.
I was planning to put the shaker on "backwards," for a Ram Air effect. I think it will look cool. Any opinions? Looks aside, forced air on an X Stream filter lid should be effective. I wonder if the 3rd gen hood isn't too raked back for the cowl induction effect to happen on the shaker. Might be starved for air at freeway speeds, so I say, mount it backwards!
Got the scoop on Ebay, so I probably won't have it for another week or two. Will post pics when I get going. Good luck with your shaker project!
See pic of the latest scoop...
Old Jul 7, 2004 | 03:58 PM
Many Threads On This Topic
I've noticed there are a lot of threads on the shaker scoop. Maybe a 100th Monkey phenomenon, because I can't stop thinking about it.
There are those who think the shaker shouldn't be done on a 3rd gen, but they couldn't be more wrong. The carbed and TBI cars especially are begging for it, and the TPI cars merely await the fab savvy. Hood birds are a must also. Of course, the aftermarket ram air hoods are super nice, but the shaker's has more X Factor--don't see too many of them.
I'm planning to install my shaker bacwards--it's an early 70's version, for a ram air scoop.
You can also buy the parts, flapper, solenoid etc. at Tachrev.com, if you want your scoop to open and shut. They've also got complete kits. I got mine off Ebay though, for 40 bucks, and I will fab whatever assembly I need. My TBI makes a glorious sucking sound as it is (no comments please) so with the scoop I should be rockin. Found a pic on another thread of how mine will look:
Old Jul 9, 2004 | 10:08 AM
Car: 1982 Trans Am
Engine: 383 chevy
I got your email, and I'm still trying to find a tool to cut the hood with. I made a template from a hood i got out of the junkyard. the hole is the pefect size, just in the wrong place, so I also have some basic measurements. I'll gather them up for you tonight and post them here. good luck. it looks like your scoop is shorter than mine, so it'll fit better.
Old Jul 9, 2004 | 12:40 PM
Shaker Template
That would be great if you posted measurements. I was wondering about that, how to locate the opening. I will still somehow mark the underside of hood for center of the TBI--mount a grease marker on my air cleaner or something, then figure out where the scoop will mount relative to that center.
The other thing is, making the edges of the hole clean. Was thinking of putting blue painters masking tape on the paint where it will be cut, so it doesn't crack or flake, then pull off the tape after cutting. Then using a dremel tool to round the edges.
Of course, we will need 2nd gen hood birds next.
Old Jul 10, 2004 | 02:03 AM
Car: 1982 Trans Am
Engine: 383 chevy
definitely. rounding the edges sounds good. I'm going to cut it tomorrow, so I'll tell you how it goes. wish me luck.
Old Jul 10, 2004 | 02:28 AM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
you should ask this in fabrication
Old Jul 10, 2004 | 08:37 PM
Car: 1982 Trans Am
Engine: 383 chevy
i will, (especially if you're telling me that there is a distinct possibility that I'll get an answer.)
Old Aug 10, 2004 | 12:17 PM
wilyk9's Avatar
Car: 85 Trans Am
Engine: 305 Carb
Mount a cutting wheel on a small angle grinder, works great. Just be careful and cut slow so you do not heat up the metal too much. Used this technique to cut the opening in the hood on my son's sunbird, clean cut, no warpage.
Cut the opening out of the junkyard hood, then cut your hood, then weld or bond the flanged opening to your hood. Little smoothing and you should be good to go, and it will look almost factory.
Old Aug 10, 2004 | 12:38 PM
sailorrick's Avatar
Car: 1982 T/A
Engine: 400 ;
Transmission: 200R ??
Does anyone have a pic of the finished hood?
never mind I just seached and found some, I think thats somethinmg I'm looking into doing.
Old Aug 10, 2004 | 03:53 PM
Remyr's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Will this work/look right on a Camaro? I need to get some more air to my nice shiney Edlebrock open element air cleaner. I can tell a major improvement just with that.
Old Aug 10, 2004 | 10:32 PM
Car: 1982 Trans Am
Engine: 383 chevy
I'm taking the cut-off wheel to it this weekend. the hood i found in the junkyard was off of a 2.8 MPFI firebird, not a 2nd gen. it's not flanged, it looks like someone cut it with a plasma cutter. i figure with some epoxy or fiberglass resin or something I can form a rolled lip around the edge of the hole I'm going to cut, so when it's painted, it'll look good. I'm marking the outline of the template on my factory hood, and the I'm going to cut the straight parts with the wheel. when i remove the plate of metal from the hole, I'll shape the edges with the cutoff wheel, a recip saw, and an angle grinder. I think it may work. if not, I'll paint the bastard and stick a set of butterflies on the intake. or a bug catcher.
Old Aug 18, 2004 | 09:42 PM
Bills87Firebird's Avatar
Hey the dork working on that 87 firebird with reversed shaker and putting the pink strips on it is me LOL
I cut my hood with a jig saw was pretty easy and you can not mount the scoop like it should be no clearence even putting it on backwards you will need to remove the rivits and repostion it but once its on it works fine makes a good ram air.
BUT think about the rain it sucks hard to seal and sucks it down easy.
Old Sep 3, 2004 | 10:58 PM
Joshua Bennett's Avatar
Car: 1988 Chevrolet Camaro Iroc Z28
Engine: 5.7 liter TPI L98
Transmission: TH- 400
what i would do is , say if you needed the hole to be 10 by 10 for example I would cut it 9 by 9 and at the corners cut 1 inch in and fold all 4 sides over to form a bur free lip
Old Oct 25, 2004 | 12:25 PM
Screamin86's Avatar
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
i was thinking of doin this mod too because the 2nd gen was a major influence on me about f-bodys but i love the 3rd gen a lot though. i had been thinking this for awhile but didnt think anyone has ever tryed it but now i have lots of info. only thing will be is finding the center of the carb on the hood. but once i get it all done it will be haul a$$ time
Old Oct 25, 2004 | 02:08 PM
LT1guy's Avatar
Car: 1987 Trans Am
Thats the easy part! Install the hood you are going to use, thread in a long carb stud, and slam the hood! The dimple will show you exact center!
Old Oct 26, 2004 | 09:37 PM
steves86TA's Avatar
Car: 2008 silverado
Engine: 5.3
If it dosent break the carb... or will it ?
Old Oct 26, 2004 | 09:51 PM
custom88camaro's Avatar
Car: 88 camaro
Engine: carby 350
Transmission: t-5 from v6 car
It definitely could break the carb, depending on how long the carb stud was. I think I would unscrew the stud just a little, then close the hood (lightly) and see if it hits. If it doesn't, unscrew stud a little more, then close hood. Try this until the hood is definitely hitting the stud, then jiggle the hood on the stud. It will scratch the paint a little. Drill a small hole from the bottom and you will have a refernce point. I think that's how I would do it.
Old Oct 26, 2004 | 11:49 PM
Air_Adam's Avatar
Unscrew it till it will touch, then put a chunk of play doh or something on the tip of the stud, so it will stick to the hood.
Old Oct 27, 2004 | 09:23 PM
Lay the scoop on hood trace around it get the scoop centered first you can always ajust the scoop on the Aircleaner by removeing the rivits.
Old Oct 29, 2004 | 11:26 AM
flyboy367's Avatar
Car: 02 redfire gtp coupe
Engine: 3.8 modded and supercharged
Transmission: 4t65-ehd
go to the fabricating forum. there is a full detail writeup of the shaker hood in there. it has pics too.
Old Nov 1, 2004 | 12:07 AM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Heres the link: https://www.thirdgen.org/techbb2/sho...hreadid=253082
cowansauto
Apr 3, 2025 12:51 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
sreZ28
Oct 22, 2015 08:21 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
SlowAZ28
Sep 2, 2015 05:19 AM
