Blending black paint?
Old Apr 9, 2004 | 05:37 PM
StealthElephant's Avatar
Car: 87' Iroc
My buddy says that I could just wetstand down to primer, hit it with gloss black, and wetsand it even. He said since black is black is black it would blend in fine. Should I do it? My rear hatch is faded really bad as well.
Old Apr 10, 2004 | 05:50 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
if ur not a good painter i wouldnt try to belnd it, paint the whole thing
Old Apr 10, 2004 | 08:18 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
black is extremely hard to blend the way you are talking about. i wouldn't do that. you will see the blend line.
Old Apr 10, 2004 | 11:08 PM
Car: 87' Iroc
The question is, will a blend line be significantly worse then the white chalking visible (as you can see in the picture). The other side of the roof is even worse, and my rear hatch is all faded.
Old Apr 11, 2004 | 09:32 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Get it done right. There is no real way to blend black, you'll just wind up repainting it afterwards.
Old Apr 11, 2004 | 11:34 AM
Car: 87' Iroc
It's just a temporary fix. Whats worse, huge white chalking spots you can see from 20ft, or a blend line you only notice from 5ft?
Old Apr 11, 2004 | 11:48 AM
Mongoose's Avatar
Car: 90 Formula
That being the case give it a shot.
Old Apr 11, 2004 | 01:42 PM
Car: 84 camaro Z28
Engine: 434sbc
its your car. do what you want. im just telling you that it isn't going to look good. why don't you just paint the whole rear of the car.
Old Apr 11, 2004 | 01:47 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
You can blend it if your good and careful. I had bad fading over my wheel wells and used that duplicolor spray can and feathered it in and no one could tell unless you were inches away.
Id use the spray can for that kind of job. a regular spray guy will have to large of a pattern.
Old Apr 12, 2004 | 06:29 PM
Charged350's Avatar
Car: 87 IROC Z28
dont rattle can it, under no circumstances, at all, never, use a real painting gun and some paint, just paint the whole car man
Old Apr 13, 2004 | 12:22 PM
maverick351ci's Avatar
Car: 1985 Firebird
DITO
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Dyno Don
17
Nov 2, 2015 11:43 PM
hectre13
Sep 8, 2015 03:38 PM
