Seatbelt trim for the headliner... how to change?!
Old Apr 12, 2004 | 09:22 PM
CaysE's Avatar
Anyone know how to take out and/or put in the seatbelt trim that attaches to the ceiling (to hold the headliner up)?? I have new ones coming and am not sure how to get these off the actual belts.
Old Apr 12, 2004 | 09:29 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The only way to remove those pieces from the seatbelts is either cut the seatbelt, or cut or break the piece. I am wording it this way because based on what you wrote, you plan to replace the trim and not the belts. Correct? If you plan to take the trim off the seatbelt assembly at the headliner so you can replace the seatbelts, there are two little tabs at the front of the trim piece. Push up on the headliner and use a small pick to pop the trim piece off the seatbelt assembly. Be careful because the tabs break easy.
Old Apr 12, 2004 | 09:36 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
Hey Bob! Do you know where I can find replacements for that trim?
p.s. the power windows/doors/release work great!
Old Apr 12, 2004 | 09:42 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hawks was carrying them at one point in different colors, they are $16.00 each. Check his site out. Glad to hear about the windows, doors and hatch. Good job.
Old Apr 12, 2004 | 10:53 PM
joshp14's Avatar
Yup. The new ones come with slits perpindicular to the slot the the belt actually sits in. You have to break the old ones off...I used some tin snips to get my old ones off. You will see the way they snap on when you get the old ones off.
Attached Thumbnails Seatbelt trim for the headliner... how to change?!-dsc00189-1.jpg
Old Apr 12, 2004 | 10:56 PM
CaysE's Avatar
Thanks Josh. You seem to be a big help lately.
Old Apr 12, 2004 | 11:03 PM
joshp14's Avatar
Not a prob bro
1992 Trans Am
May 10, 2023 07:19 PM
deracer
Apr 11, 2016 12:04 AM
lee01
Apr 9, 2016 01:56 PM
corlando52
Interior Parts Wanted
Aug 24, 2015 11:32 AM
bbernardo94
Aug 19, 2015 05:25 AM
