What have any of you's done if the front end nose has a gap where it meets the hood?
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
Hey everyone,
I have a problem with the nosecone on the front.. its just not lining up right.. i need someway to bring it up. I want to hear if any of yous have faced this problem what you have done besides by i knew front end...
Car: 82' Z28 IROC Clone (SOLD)
Engine: 355
Transmission: Built TH-350
Axle/Gears: 3.73 Moser 12 bolt
I had that problem on mine and I got it to pull down flush with some hood adjustments, If its really the nose, There are just screws holding that part on the front, make sure they're tight
Car: 86 camaro
Engine: 2.8 multiport cross fire injection
Transmission: 5 speed
Looks like the old rubber nose has heated up and warped making it lower then useual look at the midle compared to the end and then going back up near the pocket.
weird.
weird.
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
mine had a slight gap in it that drove me crazy....all I did was play around with the striker and it fixed it completely (probably kind of hard to see in the picture) it's the metal part that is on the underside of the hood:
Terrell351
Jun 13, 2021 01:13 PM
