three questions from me:)
Old Apr 15, 2004 | 10:33 PM
dieseldennis's Avatar
Car: 1987 Camaro Z28
Engine: 5.7 HO TPI
Hi all Three qustions to ask.
1) In regards to cowl induction hoods... Is there a useful purpose for the hood being like that. Or is it just for looks really.
2) What do you guys think of shaving the door handles? Is it too ***** or no?
3) I've a 87 Z28 and the drivers side molding on my windshield keeps catching the wind and flying loose. What do you suggest I do? Do I replace the whole molding or is there a glue that I can use for this? All ideas are welcome
Thanks All
Dennis
Old Apr 15, 2004 | 10:37 PM
Engine: 5.7 HO TPI
That word is r i c e y . Sorry I dindt know it was banned. I wont use it again
Another question
The rear defrost current supply pieces are peeling of my window what can I do about this that won't make too much of a mess?
thanks Again
Dennis
Old Apr 15, 2004 | 10:48 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Believe it or not, they are soldered onto the window.
Attached Thumbnails three questions from me:)-braid.gif
Old Apr 15, 2004 | 10:49 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
part 2
Attached Thumbnails three questions from me:)-braida.gif
Old Apr 15, 2004 | 10:53 PM
Engine: 5.7 HO TPI
Yikes looks a little to crazy for me I think Ill take it to GM for that one As long as it's done for winter.
Trickster... You rock! :rockon: You always come up with the good @#$%.
Dennis
Old Apr 15, 2004 | 11:05 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You're welcome Dennis.
Old Apr 16, 2004 | 02:07 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: three questions from me:)
Most people just do it for looks, but there is actual functionality to it too. The way a cowl induction hood works, is that it is a hood scoop thats flipped around backwards, and has the carb's air cleaner inside of it. By doing this, the carb will be able to suck in cold and very dense air from the high-pressure area at the base of the winsheild when the car is moving, without all of the air turbulence of a forward facing scoop. colder/denser air going in smoother means that the engine can make more power.
PS - I noticed you are from Saskatoon too.. cool
Old Apr 16, 2004 | 06:24 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
So yeah, obviously on a TPI or MPFI car a cowl is simply for looks.
Old Apr 16, 2004 | 11:20 AM
Engine: 5.7 HO TPI
Ok, got it. But Is there a way to make a hood scoop ( ram air style) operational? As to not "just" look good?
Dennis
Old Apr 16, 2004 | 12:50 PM
breakthelawinaz's Avatar
Car: 88 IrocZ
Engine: 350 Tuned Port
Transmission: 700R4 on its way out....
the cowl hood on any car would be better than stock for a few reasons, the reasons that i can think of are a fiberglass hood is lighter, and the big one i can think of is weather it is carb, tpi or tb is the fact that that area by the windsheild is a high pressure zone and ill pich nice cool air on the engine to keep it cooler and lower underhood temps and the fact that its open also allows the warm air to go out the opening intead of holding the heat like the factory hood with the mat. and as we all know lowering underhood heat will make a engine!
*eric*
Old Apr 16, 2004 | 03:59 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Not exactly true. Cowl hoods can be functional in TPI cars also. For instance, if you have a bird and you don't want to cut the hood for the Holley Stealth Ram. A cowl hood is your answer. Plus. if you know how to do some fabrication, you can use it for an air intake. Here are a few for instance....
Now without the superchargers....it can still be done.
Old Apr 17, 2004 | 12:12 AM
3gc's Avatar
3gc
Car: Z28
Shaved door handles aren't *****. People were shaving their door handles way before the import crowd started to.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
