Rear Hatch Panel
Old Apr 27, 2004 | 05:21 PM
LedZep's Avatar
Car: 1990 Formula Firebird
Engine: 305TBI w/ Functional Sport Hood CAI
Axle/Gears: SLP Posi and 3.23 Gears
Rear Hatch Panel
Can I use the panel off a 91 Firebird (the panel behind the rear glass which the brake light and spoiler mount to) on my 90 Formula with the larger wrap around spoiler and the third brake light on the panel (unlike the 91 with the 3rd brake light in the glass)? Can I just use my old panel as a template and drill the correct size holes? These panels are identical from 90 91 correct? Also how do you seal the panel to the rear glass. And any advice on removing the panel, dont the mounting bolts go through the rear glass is there a wrong or right way to remove this panel? Thanks for any help.
Old Apr 27, 2004 | 06:48 PM
Abubaca's Avatar
Hey man! What's up?
I'm pretty sure you can. You'll probably have to drill for the wiring though, like you said.
Old Apr 28, 2004 | 05:51 AM
LedZep's Avatar
what about the rubber plugs on the underside? Has anyone done this? Also how much does this panel cost new? Thanks for any info.
Old Apr 28, 2004 | 02:50 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
I doubt it's even worth it to look for a new panel.. I'd say you should just go to a salvage yard and pick one up. It's not exactly a piece that is going to have a lot of damage on it. Maybe a bit of surface rust, but that's easy to get rid of with a quick once over with sand paper.. or just get it off the next car that is in better shape.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
madsv1000
Aug 20, 2015 06:45 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
