Hatch stuck closed help!!
Car: 1988 GTA
Engine: 5.7L/L98
Well It's better than not latching at least I can drive but this is gonna start bugging me. So I have the auto hatch pulldown, my hatch will not release. I cannot open it with a key, I don't even get the clicking sound that tells you the key released the hook. It also won't respond to the interior release button. Any ideas? How do I get it open and what might be wrong?
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello Omcrider,
Here is a link to a post another individual on the board had concerning his hatch release. Go down to the post Lonsal submitted, that should help you with your problem.
https://www.thirdgen.org/techbb2/sho...readid=236300.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Originally posted by Trickster
Hello Omcrider,
Hello Omcrider,
I had a similar problem. If the key doesn't work and the switch doesn't either, then you need to pull the clear lense out(rear light) and (crawl in over the rear seat) and unbolt the solenoid and trip the latch with a screw driver to open it.
HTH
Don>>>
I posted on that site too
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
uhhhm.... my hatch will release. just the electronics are screwed. by the way i still have not figured it out yet.
