installing apc seats
Old Apr 28, 2004 | 02:02 PM
matching#s's Avatar
Car: 89 rs convertible, 99 Tahoe custom, 71 RS/SS 350 camaro (in restoration)
Engine: 305, 350, & 383 stroker
Transmission: 700r4 & Th350
Anyone have a budget friendly way to install APC seats in my 89 rs droptop? So far any adapters I have found run around $250 or so. The seats I got are beautiful and it is such a shame to see them just sit there. Thanks!
Bob
Old Apr 28, 2004 | 02:26 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
drill and mod the stock brackets
athough they may still sit too high..
then you'll have to hack at the bars on the floor pan, to make it work....
Old Apr 28, 2004 | 05:10 PM
scott's85T/A's Avatar
here is what I did to mine in this thred,, not an APC seat but it might work for you.
HERE!!
Old Apr 28, 2004 | 08:42 PM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
Transmission: T-56 LT1
I bought APC g3 racing seats a few months ago, and installed them, I simply made some brackets of my own out of flat bar steel. it isn't really simple in my case, seeing as how i went to a shop about a 20 minute drive away and was going to pure measurements. but if you have a welder and the seats out, it would be a breeze. basically the stock bolts on the floor I think are say 13" apart, now I think its the front two on booth the passa nd driver side that are offeset to one side.... I think its offset to the side of the car by about 2" than the back ones. you'd have to do measurmets but basically I just had flat bar steel that was as wide as the APC tracks, which were say 15" wide, and had a hole at each end for the track to be bolted too, and then another piece of flat bar at the front welded with a hole drilled into it for the bolts on the floor to go through. the back ones you have to make taller, I made my drivers side ones about 1.5" taller and the pass about 2.5" as the passanger side has a differnet floor style/slop
cheers
blake
Old Apr 28, 2004 | 09:13 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
:/ apc...
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Hello, Michael
Aug 20, 2015 03:19 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
