Priming/body work/filler questions
Old Apr 29, 2004 | 08:12 PM
Lhorn's Avatar
I've got the car stripped to bare metal (because the paint was crcked) and ready to prime (will use PPG products) and do small amount of body work. I have a few questions
1. I'd like to use an etching primer. How many quarts will cover the whole body if sprayed with a conventional gun? Will 2 quarts of primer with 2 quarts of catalyst be enough to give a couple of coats or do I need closer to 3 or 4 quarts (plus the equivalent amount of catalyst)?
2. I want to use a bit of evercoat filler. I understand this can be done on bare metal or on a primer, but not directly on or under an etching primer. Would you spray the etch, then an epoxy, then filler body work, then a surfacing primer (block, block, block) then topcoat? Or should I put the filler on bare metal, spot cover the filler with epoxy primer then hit all remaining bare metal with etching primer (then surfacing primer, etc)?
3. Before I primer, I was going to give the car a once over with a finishing sander loaded with 80 grit. Then Acryliclean, then shoot it. Sound ok. If I chose to put filler on bare metal should I rough it up with a coarser grit like 36?
4. What is the best cleaner to use right before priming/painting? I've got Acryliclean. Is that a good final solvent or do I need something else?
Thanks in advance.
Old Apr 29, 2004 | 09:32 PM
jay92,85,79's Avatar
Car: 85z28,
Is it evercoat glaze or evercoat bondo.With the glaze u can go over primer or bare metal.If it was me i would do the body work than etch primer (1 should be enuff) I hve allways gone over my bondo work with the etching primer.I don't know if this is right or not but the first car i painted the 2nd time i sanded it down the paint allmost just feel off.I would use 320 for the last sanding and i allways use painters pride pre cleaner.
Old Apr 30, 2004 | 12:27 AM
Lhorn's Avatar
I meant the evercoat version of bondo. Just a few shallow dings. I guess that I've heard the acid etch primers don't mix well with fillers. Just wanted to see what people thought of that.
Old Apr 30, 2004 | 04:29 PM
Car: 85z28,
If u are useing bondo that has to go on bare metal.The stuff for small dings that u can use over primer is the glaze its called evercoat.
Old Apr 30, 2004 | 05:07 PM
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Use Epoxy Primer.. it's just as good as the other stuff. and goes on very nice. and works over fillers too.
Old Apr 30, 2004 | 08:12 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
yeah i would almost always do your body work on bare metal other wise you have a chance of it poppin out on ya or crackin because all its bonded to is the (paint/primer) you installed it on top of .....
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
