Wind noise from windows, though windows are closed!
Old May 1, 2004 | 11:08 PM
ajmcmahon's Avatar
Car: Pontiac Trans Am
Engine: Stock 305
Q: How can I prevent the wind from coming in around the door window?
A: Take off the door panel and on the inside of the door there are white plastic taps that take a 10mm wrench. Move them ever so slightly up and this will let the window come up a little higher. You will have to play with it a bit to get it just right.
found it in the FAQ article, but it doesnt really say much about it.
has anybody done this? can you elaborate on it a little bit.
( i always thought it was foam or the rubber around the windows that has rotted away... but could never find a hole )
Old May 3, 2004 | 06:51 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
take the door pannel off, you ll see ..easy...
Fronzizzle
Sep 8, 2015 12:10 PM
GouldyGTR
Sep 7, 2015 09:05 PM
Randomtask2
Sep 7, 2015 05:06 PM
SG91camaro
Sep 5, 2015 10:27 PM
luvofjah
Sep 3, 2015 07:08 PM
